How to fix slack drop wire
JRT
After a visit to my nearby pole by OpenReach last Saturday (July 16th), I noticed that the drop wire between pole and house is now very slack and "blowing around in the wind".  I'm concerned that it will eventually let go and disconnect my line. How does one go about getting this sorted as its outside the property and therefore a BT/OpenReach issue?
Many thanks
20 REPLIES 20
Fixes: 118
Re: How to fix slack drop wire
@JRT
If you consider it a safety issue you can contact OR direct - it's the one time they'll speak to you.
Look at https://www.openreach.com/help-and-support/damage-health-and-safety
Mustrum
Fixes: 81
But is it really a safety issue?
Fixes: 388
@Mustrum Possibly not, but I wonder if it could be a contributory factor to the OPs other topic?
JRT
Probably not a safety issue, but certainly an issue if/when it falls off! I will contact BT during today and post their response.
Strat
Fixes: 565
My pole to property line hangs lower than any of the other lines from that pole.
It has done so for a lot of years and swings wildly in a storm but it's still there.
They are pretty tough.
JRT
Thanks for that. It’s comforting to know other folks have a similar issue. I do recall from folks I used to know in BT that things like this were picked up by line folks as and when the pole was visited. Now, if it isn’t on the job sheet it won’t get fixed!  Unless, of course, it disconnects entirely and causes a fault. Which could have been avoided - if only.
I will pursue the BT link and see what happens.  I'll post back if (when) anything changes
Fixes: 1,664
Have you had your dropwire sorted yet?
Let me know when you could be available for a visit if not and I can arrange an engineer with you to fix. The engineers are available weekday timeslots (and occasionally Saturday's) of 8am to 1pm or 1pm to 6pm.
RobPN
Fixes: 15
Just a thought @Gandalf, why would a customer need to be available for a dropwire 'adjustment'?  Surely it'd just be done from the pole end by re-twisting it onto the 'curly tensioner'?  Smiley
Fixes: 1,664
Correct me if I'm wrong but the drop wire connects on to a customers property, so the engineer would need permission to access their property and this is arranged in the form of a visit.
Having said that, the type of fault I'd be raising is an "overhead damage report" which tasks out an engineer within 24 hours with no option to book an "appointment" at that stage.
I think the main question at this stage: is this resolved yet?
Fixes: 118
@Gandalf
Are you aware the OP had / has a second thread running on performance issues.
Fixes: 1,664
Yeah maybe it's best getting the drop wire fixed first before investigating a speed issue.
JRT
Hi Anoush,
The drop wire issue is still outstanding, so thanks for picking this up. Suitable slots would be weekday afternoons (1-6 pm) this week or next week from Wednesday (3rd August) onward.
Please let me know what happens next.
Regards,
Fixes: 1,664
Cool. I've raised the task now with Openreach and an engineer should be allocated within 24 hours.
I can't guarantee they'll go out in the afternoon as this type of task is classed as external in the supplier system, even though I can be reasonably sure the engineer will need access to your property.
The engineer should call you either way though and if you aren't around when they do call, then they'd likely pass the job back to us and I can arrange an appointment with you for a specific timeslot.
JRT
Brilliant, thank you.  Someone should be around for access if required.
