No home phone - landline number?
- Home Phone
- No home phone - landline number?
30-07-2022 7:52 AM
Hi all,
Is there anywhere on my plusnet account that tells me what my landline number is? I can't see it under My Account.
Thanks,
Daren
Re: No home phone - landline number?
30-07-2022 7:59 AM
Login into the members centre https://www.plus.net/member-centre/home select Phone, this takes you to the Phone Control panel
HTH
01-08-2022 6:25 AM
No option of a phone control panel. I get my landline as part of the broadband package, does that affect where I can see the landline number?
01-08-2022 7:42 AM
My landline is part of my package, I see this in the members centre.
Just checked and you can get to the Home Phone Control Panel via Manage Account.
HTH
Dan
01-08-2022 12:52 PM
Hi Daren,
Does the phone tab show your landline number?
01-08-2022 1:09 PM
01-08-2022 1:12 PM
If you're asking because you don't know your number, call 17070 (free) using a phone attached to your line and listen to the number read out to you.
01-08-2022 1:25 PM
The title suggests he doesn't have a landline phone, so the members centre would be the obvious way to check. Perhaps he can borrow a landline phone.
It's a bit of a concern he can't find it in the members centre.
- Home Phone
