Moving a Master Socket
xMtch
My current master socket is in the hallway/dining area, but I want it moved to the lounge, which has my office above it. I am not getting the guaranteed speeds and I believe moving my master socket will improve this.
I've seen posts on other forums saying Openreach are the people to contact, and others saying your provider is the first point of call.
Could someone please point me in the right direction to do this?
Cheers
9 REPLIES 9
Fixes: 383
Re: Moving a Master Socket
@xMtch I doubt moving the Master socket would make much difference. When you say you are not getting the guaranteed speeds, how far off are you, and what service and router are you using?
To get it moved, you do have to go through Plusnet, and I understand OR charge £160.00+VAT for the privilege.
xMtch
well our guaranteed speed is meant to be 37.5mbps download and 15 upload. We are lucky if we get 20 download, and 5 upload.
It previously was under 10 download when we moved into the property over a month ago, and got an engineer to come out and try to increase the speeds, but it's still not what i'm paying for, which is why I'm tempted to see if moving the socket would increase the speed.
We have the best package we can get, which is fibre as full fibre is not available as of yet. We have the Plusnet 2.0 router I believe.
Fixes: 480
@xMtch
It sounds like you are connecting via wireless. Guaranteed speeds only apply to devices directly connected over Ethernet.
You could always install an Ethernet cable between your halfway and lounge and fit a wireless access point in the lounge.
xMtch
If I could install an enternet cable between the two rooms, what would be the best way to do it without it looking messy? I have tried a Wifi extender, but that made no difference.
What else would you suggest I do?
Fixes: 383
As I said, moving the socket will achieve little, if anything.
I appreciate the following means a little work for you, but if you provide it, maybe other Community members can make suggestions:
BTW Performance Tester - Over a wired (Ethernet) connection if at all possible, please report the 'ADDITIONAL DIAGNOSTICS'- if it will run. This test is recommended to be performed with only one device connected.
For the Hub One -
For the Hub Two -
Fixes: 383
There are flat Ethernet cables which which you can use.
xMtch
Thank you for the post. I will do all of this when I get back home from work.
We do not have a home phone, so I cannot do the last part, unless it's possible to do on a mobile.
Fixes: 383
No problem about the phone - just do all you can.
Fixes: 480
@xMtch
If the master socket was moved to the lounge, what would be the route? A CAT5e Ethernet cable is about the same diameter. Every property is different. You can use up to 100m of CAT 5e so length of cable is not an issue.
Is there an external route? If so either use conduit or use specified outdoor cable.
