How To Cancel / Remove a Permanent Number Witheld
Heriberto52a
Hi When someone dials our landline to call me on my mobile phone, the number comes up Number Withheld. This seems to be permanently switched on and nothing the person calling me has done. How can I get this switched off? I have looked up the settings in the panel on the Plusnet Website and can't find this option to switch it off.
1 REPLY 1
Fixes: 251
Re: How To Cancel / Remove a Permanent Number Witheld
Hello,
Your question is not clear - "When someone dials our landline to call me on my mobile phone, the number comes up Number Withheld".
Do you mean you have given your mobile to someone to use to call your landline number?
Do you see "Number withheld" on the landline telephone when the call comes in from that mobile phone?
Do you see a calling number when other phones call the landline?
If yes to both of the first, then your mobile phone is not set to disclose its number.  That has nothing to do with your Plusnet provided landline telephone service.
If no to the last - you never see a calling number displayed - then there could be a fault on the landline telephone.
