Mobile Phone Add-on
- Home Phone
- Re: Mobile Phone Add-on
Mobile Phone Add-on
05-01-2016 12:18 AM
I have FTTC broadband and Anytime phone with Plusnet. I recently signed up for the International calls add-on. I then thought it would be beneficial to pay an extra £3.00 per month for free calls to mobiles in the UK. When I applied I was surprised and very disappointed to be told that, because I had the International calls package I could not have the mobile calls package. The reason given is that " the simple case is that the products simply do not work together ".
I am not impressed with the answer I received. It may just be that the Plusnet system cannot distinguish between free calls to international landline numbers and chargeable calls to international mobile numbers. Has anyone got other suggestions as to why Plusnet are playing hardball?
Message 1 of 5
(2,764 Views)
4 REPLIES 4
05-01-2016 10:51 AM
Normally we'd be able to apply both together but having LRS on the same account has complicated things.
Apologies for the confusion over this but I'm going to speak with our billing team to see what we can do to get both running in conjunction.
Message 2 of 5
(1,037 Views)
05-01-2016 12:35 PM
Just to clarify, the problem is occurring because you're currently on a legacy phone package from before we offered the mobile minutes bolt on. We should be able to get it sorted out for you though
Message 3 of 5
(1,037 Views)
05-01-2016 4:36 PM
@trymyluck
We need the help of a particular person with this who isn't available at present but I'll pick this up with them tomorrow for you.
UPDATE:
FYI we've just managed to fix this for you, Just to let you know we've had to do this by removing and adding the line rental saver contract as a result this may mean you get billed a few pence for a couple of calls.
If you do find that has happened from the next bill then reply back to this thread or drop me a PM and I'll get it refunded.
UPDATE:
Message 4 of 5
(1,037 Views)
07-01-2016 11:46 PM
Thanks very much Adam for taking the trouble to sort this out. for me. I am sorry it was necessary to raise this in the Plusnet Community Forum for a solution. Perhaps the complaints advisers in Customer Support need to raise their game a bit..
Message 5 of 5
(1,037 Views)
