I was wondering if someone could help me
dangermouse1983
I was wondering if someone could help me get a update on the curren issu
I once again have a crackling sound of my line I did raise this issue and awaiting an update
I already had 4 engineer visits over the last year or so I really do not understand why this issue keeps reappearing
I would really appreciate it if someone from plusnet can look into
40354697
many thanks
dennie
16 REPLIES 16
dangermouse1983
Re: I was wondering if someone could help me
very disappointing  I was hoping someone would help me at least  Undecided
hulls
I'm not an engineer, but we did have a similar issue.  What tended to happen was that the engineer would switch us to a new pair of wires at the green box, and that would fix it for a while (I suspect what happened then, was that someone else complained about a crackle on the line, and the engineer swopped their wires, and so on until we got the bad pair again, but then I'm a natural cynic  Wink )
itsme
Don't think so as there's a lot of work involved in swapping pairs as not only work has to be done in the street cabinet but also the exchange.
Strat
Fixes: 565
If you get your voice service from BT then it's them you should be reporting the fault to as Plusnet cannot really do anything.
However if you transferred your voice service to Plusnet they could then chase up the fault.
If you already take your voice service from Plusnet then ignore the above.
dangermouse1983
no my phone line is definitely with plusnet I found them on Tuesday I got told it will take up to 72 hours to test
but have no reply yet .
198kHz
Fixes: 41
Quote from: itsme
Only if it's a swap between exch and cab, but not if it's between cab and customer.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
hulls
Quote from: itsme
The engineer told me on at least 2 occasions that that's what they'd done.
itsme
Quote from: 4C
I few yards from the cab to the customers vs the cab to the exchange which could be a few miles. Which has the highest probability of having a problem?
198kHz
Fixes: 41
Quote from: itsme
That's a rather sweeping generalisation.
Quote from: itsme
D-side (cab to customer), as the E-side cables are pressurised.
itsme
Quote from: 4C
Surprising that so many bar pairs can't be used because of permanent faults on them,
198kHz
Fixes: 41
More economic to fix them all at once if pairs run short, or replace a section, than dig up large E-side cables every few weeks.
dangermouse1983
I've just race a to another ticket regard to issue
as I have not  received update at all.
orbrey
Hi Dangermouse,
Sorry to hear that, do you still hear the noises when there's just one wired phone plugged into the master socket and everything else removed from the line?
dangermouse1983
hi
yes noises still there got told had to test the line that was last tue sins then no word at all?
dick:quote
