I was wondering if someone could help me
- Home Phone
- I was wondering if someone could help me
04-03-2011 11:30 AM
I once again have a crackling sound of my line I did raise this issue and awaiting an update
I already had 4 engineer visits over the last year or so I really do not understand why this issue keeps reappearing
I would really appreciate it if someone from plusnet can look into
40354697
many thanks
dennie
Re: I was wondering if someone could help me
05-03-2011 12:24 PM
05-03-2011 12:27 PM
05-03-2011 1:37 PM
05-03-2011 1:50 PM
However if you transferred your voice service to Plusnet they could then chase up the fault.
If you already take your voice service from Plusnet then ignore the above.
05-03-2011 2:43 PM
but have no reply yet .
05-03-2011 2:47 PM
Quote from: itsme Don't think so as there's a lot of work involved in swapping pairs as not only work has to be done in the street cabinet but also the exchange.
Only if it's a swap between exch and cab, but not if it's between cab and customer.
Zen FTTC 40/10 + Digital Voice FRITZ!Box 7530
BT technician (Retired)
05-03-2011 2:48 PM
The engineer told me on at least 2 occasions that that's what they'd done.
05-03-2011 3:17 PM
Quote from: 4C Only if it's a swap between exch and cab, but not if it's between cab and customer.
I few yards from the cab to the customers vs the cab to the exchange which could be a few miles. Which has the highest probability of having a problem?
05-03-2011 6:38 PM
Quote from: itsme I few yards from the cab to the customers vs the cab to the exchange which could be a few miles.
That's a rather sweeping generalisation.
Quote from: itsme Which has the highest probability of having a problem?
D-side (cab to customer), as the E-side cables are pressurised.
05-03-2011 6:51 PM
Quote from: 4C D-side (cab to customer), as the E-side cables are pressurised.
Surprising that so many bar pairs can't be used because of permanent faults on them,
05-03-2011 9:10 PM
06-03-2011 12:33 PM
as I have not received update at all.
07-03-2011 11:07 AM
Sorry to hear that, do you still hear the noises when there's just one wired phone plugged into the master socket and everything else removed from the line?
07-03-2011 3:56 PM
yes noises still there got told had to test the line that was last tue sins then no word at all?
dick:quote
- Home Phone
