? Faulty line
- Home Phone
- Re: ? Faulty line
? Faulty line
10-09-2021 2:35 PM
My land line w/o t accept in coming calls and there's no dialling tone. Phone will ring it's partner and vice versa. A y ideas most appreciated.
Message 1 of 3
(1,077 Views)
2 REPLIES 2
Re: ? Faulty line
10-09-2021 7:25 PM
Get a known working, corded telephone, and connect it to the test socket on your BT master socket. (you'll need to remove the 2 front screws to do this).
If there is still no dialtone, you'll need to report the fault to Plusnet who will arrange for Openreach to fix the line fault.
Message 2 of 3
(1,042 Views)
Re: ? Faulty line
12-09-2021 9:34 PM
Hi @PaulaT2
I'm sorry to see your phone doesn't work. I've tested your line today and the tests are showing a fault on the line, so I've reported this to our suppliers and we've been given an estimated response time of by 15/09/21 23:59:59 for an engineer to go out and investigate further. We'll provide an update Here as soon as we know more.
Message 3 of 3
(1,002 Views)
