Dital switch confusion
Fixes: 387
Re: Dital switch confusion
In that case then, the only thing you will need to do is unplug from the upstairs plug socket and plug into the phone socket on the router. Honestly don't know if the BT phone would work, though.
Fixes: 387
@nuttyknitter wrote:
My latest 'middle of the night' worry is my computer connects to the internet using an ethernet lead. It doesn't have wifi.
I am sorry to keep asking more things, I feel such a dope.
That connection is perfectly OK, and should continue to function.
Don't apologise for asking questions - if you don't know, that is the only way you will get answers, and why the Community exists.
Fixes: 585
@nuttyknitter
We have a Panasonic base phone which is plugged into the phone socket upstairs and a handset phone downstairs. We also have a BT phone plugged directly into a phone socket in the kitchen.
Aa @jab1 says, the base will plug into the new router and the handset downstairs will still work.
The phone plugged into the phone socket will NOT work though.
pvmb
Champion
Fixes: 16
@pvmb  My email is with Yahoo
Thanks! That's OK then, no problem there with moving away from Plusnet.
Fixes: 118
@nuttyknitter
House phone extensions don't work with VOIP without some work. Quite easy with Full Fibre but a bit more complicated with SOGEA (FTTC without the phone).
As you have two DECT phones these will work as normal but you'll lose the BT phone in the kitchen. Can you add units to the DECT system you already have?
Did you check the OpenReach site to see what it says for Full Fibre?
Fixes: 387
@bmc Given the abysmal figures for this customers connection, I would hazard a guess that they are in a remote/hard to reach location, which mean FTTP is likely to be a long way off.
Fixes: 118
@jab1
You could well be right but there's no harm / cost in checking.
Fixes: 585
With those estimates, voip might be a struggle especially when there's other traffic on the connection
Fixes: 387
Good point, @MisterW , although it should be OK on SOGEA?
Fixes: 585
But even the SoGEA estimates are low, indicating a long line. That likely means high error counts and latency.
The upstream estimate is 800k and whilst 200k is technically sufficient for voip,  if there's any other traffic ?
I don't know if/what SQM is implemented by EE for their digital voice, I hope it's good...
Fixes: 387
Fair enough, and I take your point.
nuttyknitter
@bmc  Yes I went on the website and it said there are no plans to bring Full Fibre to us.
I will look into whether I can buy some extra handsets and hopefully I will be able to get another one.
Fixes: 387
@nuttyknitter what is the exact make and model of your DECT phone?
nuttyknitter
We are a third of a mile down a lane from a main road, between a village and a small town. I think Openreach put something in underground at the top of the lane next to the main road. There is a sort of slab thing over the top of it.
My computer is slower when the kids come out of school in the afternoon, so I guess they take something off what I can use.
Fixes: 387
That will be a chamber, to allow connection to properties in the vicinity, @nuttyknitter . Your location is 'off the beaten track', so it will be a while until they get to you.
