Disable 1571 voicemail
cdhinton
Hi all,
Is there a way to disable 1571 voicemail? I have an answerphone so don't really want to have to check two places for messages. Can't find an option in the home phone control panel, though.
Thanks in advance.
8 REPLIES 8
198kHz
Fixes: 42
Re: Disable 1571 voicemail
If you're on this page - https://www.plus.net/plustalk/index.php?page=wlr_my_account
it's the third tab, Call Features, below the words Home Phone Control Panel. Untick Voicemail.
BT technician (Retired)
cdhinton
Thanks - it isn't ticked, though, and doesn't appear on the list of features to remove 😕
EmilyD
Aspiring Hero
Fixes: 117
Hi @cdhinton,
I'm sorry to hear that you have been unable to remove the voicemail 1571 feature via the home phone control panel. I've checked and this feature wasn't showing as active on your Plusnet account but was on our supplier's system, so I think this is where the problem has arisen. I've placed an order to fully remove this from your line now, please allow 24-72 hours for this to complete.
 Emily D
cdhinton
Thanks @EmilyD, much appreciated.
MDC3004
Hi, I have the same problem. Can 1571 voicemail please be disabled on my phone as it is an absolute nuisance. Again there is no option on the home phone control panel to remove it.
Fixes: 1,660
Hi there.
This should be sorted for you within the hour.
Let us know if you have any further issues.
MDC3004
Thank you very much for the prompt reply.
Fixes: 1,660
No problems.
