Cost to replace BT Master socket
dawson
Can someone tell me price to replace the BT Master socket please - it is old and quite manky.
I have been having intermittent connection drops which decreased when I took the front plate off and connected to the hidden port so I think it would be a good idea to get it replaced.
21 REPLIES 21
Fixes: 385
Re: Cost to replace BT Master socket
Report your connection drops and quite often if this results in PN finding faults, the OR engineer will replace the master socket FOC as part of the repair.
If the phone test passes, report a broadband problem via: https://www.plus.net/help/report-a-problem/broadband/
The above assumes you still have 'normal' landline connection - if you have a SOGEA (internet only) one, just use the second link to report a network issue.
dawson
Thanks for the reply - Phone line sound is clear - will try your other suggestions when I get home.
Fixes: 385
If you are not at home - how have you tested the line? The test must be done from your premises.
dawson
Sorry - possibly talking at cross purposes.
Last night when I picked the handset up - the sound was clear, no crackling etc
I will run the test you suggested tonight and get back to you
Fixes: 117
@dawson
I assume FTTP isn't on the horizon. This would bypass the Master Socket.
The checkers ar in the process of updating following the announcement of more Exchanges to be done. It might just be worth a check.
https://www.broadbandchecker.btwholesale.com/#/ADSL (you're looking for WBC FTTP in the left hand column)
https://www.openreach.com/
dawson
hmm, it looks like it is available - so that would bypass this whole issue!
I still have around 18months left on my current deal.
I will need to consider the implications of losing the landline/telephone number.
Fixes: 117
@dawson
Yes, It's available. An entirely new fibre optic cable is run to your house terminating at an Optical Network Adapter (ONT). Sometimes it comes in via the existing entry point for the copper cable, or else by a new drilled hole.
https://support.aa.net.uk/Openreach_FTTP_ONT
You do lose your landline but not necessarily your phone number, You can port it immediately after install to a VOIP provider.
PN will upgrade you at any time at the cost of a new contract. The lowest speed on full fibre is 78 down so it looks like you'd get a doubling of speed without even considering the faster products.
I would continue with the fault checking while you think about things. Two things to consider - what's you mobile signal like and is your phone number important to you.
dawson
Did the 17070 check and it was silent apart from the recording.
It has dropped the connection this evening, but has reconnected.
Will continue to monitor.
Fixes: 385
@dawson Going back to your original post, you said that using the test socket reduced the frequency of drops, which clearly indicates there is an issue - it is in your interest to get this rectified ASAP, so I strongly suggest you report a fault using the second  link in my post, otherwise you may find that your internet connection may fail totally.
Your choice, but it is a step I would take.
mystreet1
Seasoned Pro
Fixes: 7
If you have a Telephone ADSL Filter adapter lying around, take of the face plate and plug that into the test socket.
My socket when wrong years ago, dropping connection, low speed. Plugged one in, nearly 39Mb download on a 40Mb connection.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 385
@mystreet1 If you read post #1 again, I think you will find the OP has already done that, and the results from that indicate a fault  with the faceplate of the master socket.
HPsauce
All Star
Fixes: 5
If it really is the faceplate just buy an appropriate filtered faceplate online.
Exact model will depend on the type of master socket.
(I've got loads of the things now of various designs as they evolved over the years, even an i-Plate!)
dawson
Hi, just to update the thread...
After posting last night the connection dropped at 11pm and stayed off all night.
This morning an engineer arrived unexpectedly - I had logged the issue prior to posting here.
He has replaced the master socket and it has been connected for over 8hrs and I am now getting 40 down and 9.95up!
So hopefully the issue is now resolved.
Fixes: 385
So, it appears it was a fault with the Master socket as I suspected - they can fail, and as yours appeared to be old and in poor condition, that probably explains it. I assume he replaced the socket with a 5c/Mk.4 version?
