Using the Plusnet Hub 2 router for VOIP ?
ChrisK99
It appears that Plusnet will not be offering a VOIP solution. The Hub 2 router has some hardware support for VOIP but would this work with a third party VOIP provider? If (as I suspect) I'd need a separate hardware adapter, any recommendations? There are plenty of cheap ones on Amazon and eBay, but I'm not sure how good they are.
1 REPLY 1
Fixes: 586
Re: Using the Plusnet Hub 2 router for VOIP ?
@ChrisK99 The Hub 2 router has some hardware support for VOIP but would this work with a third party VOIP provider?
It might have an FXS port but it's not supported in the firmware, so No!
Many people on here use the Grandstream HT series , not cheap but they seem to work well
Let use know what you're considering and we'll try to help. Beware that cheap ATAs are sometimes 'locked' to a voip supplier/
