Cost of relocating master socket - why so high?
myloginname
Just had to pay £160 to arrange relocating our mastersocket because of building work (After a joyous 32 minutes on hold listening to horrible music interspersed with static!). It seemed like we didn't have much choice in the matter but the cost seems a bit weird.
According to BT openreach it costs £130 to move a mastersocket. But the customer service agent told me there was no point phoning BT because they'd insist I contact our provider.
Also, under the help info on moving house, in order to install a new phone line and move your broad band its costs £49.99 installation, plus £65 to move the broadband = £115. Apparently though I can't 'move house' and stay at the same address.
So i'm just wondering why the fee from PNet is that bit higher, given all this?
5 REPLIES 5
Fixes: 463
Re: Cost of relocating master socket - why so high?
Does the Openreach price include VAT? With a bit of rounding up 130 plus 20% is pretty close to 160.
azc
From the price guide :
For converting hard-wired master sockets (and any other conversion charges) a £160 charge is payable for the first hours work and after this a £65 per hour (or part hour) charge applies.
myloginname
Thanks, it could be plus vat, that would explain it - its a struggle to find out concrete information online and its frustrating when companies aren't transparent, but hey ho.
As for the charge covering the first hours work only - the customer service agent made zero mention of that, just that it would cost £160 to do! I guess technically the master socket isn't being converted (I assume that means to another type of line/service) its just being relocated.
ejs
Aspiring Hero
Fixes: 25
Where did you get the "£130 BT Openreach" price from?
According to the Openreach price list, under Service Product Pricing, 4.1.1 Time Related Charges, the Openreach price for an NTE Shift is £105.60 ex. VAT.
notmyname
More to the point, as long as you don't have any extensions wired in.  You could probably do the job yourself for under
£30.
