Compensation
Rodders708
Compensation
For the period starting 29 Mar to 11 Apl we were unable to receive incoming calls should we be compensated automatically, because we have not had any.
10 REPLIES 10
Mustrum
Fixes: 81
Re: Compensation
Did you report a fault?
Rodders708
Re: Compensation
Yes
MatthewWheeler
Fixes: 503
Re: Compensation
Morning @Rodders708
I'm really sorry to hear you had a fault on your line and that you weren't compensated for this.
I've sent off a request for this to be manually added and we'll get that done for you as soon as possible
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Rodders708
Compensation
According to Matthew Wheeler, compensation for a phone fault (for approx 2 weeks) would be manually adjusted on my next bill June), this has not happened!!
This should have been done automatically without any input from myself according to Ofcom, which Plusnet signed up to.
Your comments would be appreciated.
Fixes: 1,495
Re: Compensation
Moderators Note
Topics merged.
MatthewWheeler
Fixes: 503
Re: Compensation
Sorry to hear this still hasn't happened @Rodders708
I've escalated this further and we'll update your account shortly
Rodders708
Re: Compensation
We have been credited with £100.00, can you tell me how you arrived at this figure because it not tie in with the Ofcom measure of recompense. Cheers.
MatthewWheeler
Fixes: 503
Re: Compensation
Thanks for getting back to us @Rodders708
I've created a ticket on your account with the details.
Let me know if there's anything else we can help with
Rodders708
Re: Compensation
Thank you, where exactly is this ticket on my account?
MatthewWheeler
Fixes: 503
Re: Compensation
If you go here you should be able to view it
