BT 4600 Blocker Phone - Caller ID/1571 caller messages ?
Fixes: 1,652
Re: BT 4600 Blocker Phone - Caller ID/1571 caller messages ?
Hi @Davexxx
I'm sorry to see we've removed Call Protect. I've now re-added the service and it should start working within an hour.
Let us know if there are further issues or anything else you'd need help with.
Moderators Note: Grammar corrected
Davexxx
Plusnet: FYI the erroneous disabling of 'Plusnet Call Protect' has completely erased my (extensive) personal 1572 list of blocked callers.
Fixes: 466
@Davexxx
Now you have a BT 4600 then you will not need to block spam calls that bypass your 1571 service, the phone built in blocker will do it for you automatically.
RealAleMadrid
Fixes: 68
@Davexxx  As Baldrick1 says you no longer need to block numbers with Plusnet Protect. It is a hopeless version of BT's equivalent which has a web interface to easily set up white list and blocked numbers. Having to do it all via the phone handset is just not worth bothering with, I have never used it. Not sure why you want it enabled.
Davexxx
"Now you have a BT 4600 then you will not need to block spam calls that bypass your 1571 service, the phone built in blocker will do it for you automatically." - Understood.
But why have I received another two messages from Plusnet (this afternoon), again without any prior instruction from myself:
1) "We've received your order to change your call features. The following will be removed:
* Plusnet Call Protect
We'll email to confirm when this is complete."
2) "We've completed the changes to your Call Features. We've removed the following:
* Plusnet Call Protect"
adam945
Fixes: 113
Morning @Davexxx
Thanks for reaching out again and I'm sorry to see that for whatever reason, our automated system has removed Plusnet Call Protect, it's unclear why, though if I were to guess, I'd say it's something to do with the features that are actually on the line itself. The features required for Plusnet Call Protect are:
  • Voicemail 1571 with greeting (or without)
  • Caller Display
  • Choose to Divert
I've now ensured that these features are on the line, and have re-added Plusnet Call Protect. Please let us know if this is removed again and we'll follow this up.
 Adam
 Plusnet Help Team - Leeds
