1572 Call Protect Number Blocker - Leave a Message Option
caravanj
We use the 1572 Call Protect number blocker but it allows a caller to leave a message. The whole point of us using Call Protect is because we don't want calls from these numbers, nor do we want to give them the option to leave a message.
We have 1571 voicemail disabled but we can't find an option to disable 1572 blocked number messages.
 Is it possible to do this?
Thanks for any help.
7 REPLIES 7
ThePillenwerfer
Re: 1572 Call Protect Number Blocker - Leave a Message Option
I quite agree.  I haven't even activated it on my line as the caller being able to leave a message seems to defeat the whole point.
OskarPapa
Fixes: 65
Hi @caravanj, thanks for your post.
Unfortunately, you're not able to turn off the junk voicemail feature. That being said, it shouldn't interrupt your dialing tone in the same way as regular voicemail and so we'd recommend simply not listening to the voicemails.
Once 10 are stored, the oldest would be deleted by the system if a new one comes in.
We're sorry for any inconvenience caused.
caravanj
We activated Call Protect as it does it's job of stopping the calls coming through but we'd like the option of making it clear to those callers that we don't want any contact with them by not inviting them to leave message.
caravanj
@OskarPapa; Does Call Protect only store 10 numbers?
We don't listen to any messages, it's the fact that it gives the caller the impression that we might still want contact with them, when we don't.
Just checked, it stores 100 numbers.
Fixes: 1,662
Hi there.
Unfortunately we don't have any control over Call Protect bar turning it off and on.
Apologies again for the inconvenience this causes.
caravanj
@Gandalf It's not a problem, it stops the calls getting through which is what we wanted.
Thanks for all the replies.
Fixes: 1,662
No problem.
Let us know if there's anything else we can help with.
