Hiho
1571
I have a voicemail service already set up on my phone so want to remove the 1571 option. A previous member suggested changing the voicemail to cut in ahead of the 1571 but I need to have more time to pick up the call. Any thoughts much appreciated.
4 REPLIES 4
198kHz
Fixes: 42
Re: 1571
Welcome to the forum. 🙂
You should be able to opt out of the 1571 facility if you log into the Member Centre, click on 'Phone', then 'Add or remove call features'.
BT technician (Retired)
MatthewWheeler
Fixes: 503
Re: 1571
Hi @Hiho
I'm sorry for any inconvenience having 1571 active on your line is causing.
I've asked our suppliers to remove it for you and it should be gone now
Let us know if there's anything else we can help with
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
Hiho
Re: 1571
That's really useful info, thank you. I didn't get around to testing it out as the issue got sorted pretty quickly!
Hiho
Re: 1571
Fantastic, all sorted. Thanks very much.
