Unknown call charge ?
SirLurkalot
My sister's bill has 20 20p call charges this month, each has no call destination, described as other, and no call length. What are they? Thanks.
7 REPLIES 7
Fixes: 581
Re: Unknown call charge ?
Call return has a fixed 20p charge , is that a possibility ?
198kHz
Fixes: 42
It's the same charge, I believe, for Ring Back, where you press 5 after getting engaged tone and you're called back when the line is free.
BT technician (Retired)
SirLurkalot
Thanks for the suggestion. What exactly are call returns? I assumed if she called back, it would just be charged as another call. She not entirely with it, so anything's a possibility !
SirLurkalot
I can't imagine she'd know about that but I'll ask when I get a chance. Thanks
198kHz
Fixes: 42
 Call Return is where you press 3 to return the call to a number announced on 1471.
Fixes: 479
Or a reminder call. https://www.plus.net/help/legal/residential-phone-tariffs/
SirLurkalot
I can only imagine that she's suddenly doing something inadvertently, which she doesn't understand. I will have to check next time I go there. Thanks for the quick replies.
