Fibre to Cabinet
richardkendell
Fibre to Cabinet
Our home phone relies on power through the copper network. I am aware that if I switch to full fibre the phone will stop working (or need an additional power source) but if I switch to fibre to cabinet will the phone continue to work as at present or will I need a power source as with full fibre?
4 REPLIES 4
Fixes: 476
Re: Fibre to Cabinet
@richardkendell
With FTTC the phone wiring is not touched so the phone will still work during a power cut.
Fixes: 382
@richardkendell FTTC still uses the copper cable from the street cabinet to your home, and works as normal. With FTTP, you will not have a landline phone service, rather you will need to set up a VoIP service - currently, PN do not supply this.
richardkendell
Thanks for the prompt help
Fixes: 115
@richardkendell
Do you have a choice? Use the following to check.
FTTC shows up as VDSL. For FTTP you need to see WBC FTTP in the left hand column. If one of hte Alternative FTTP operators has installed a fibre netwrok in your location then your OpenReach connection would be untouched by an install from that source.
