xbox live connectivity issue
vespy
Re: xbox live connectivity issue
tried 4 other filters, the other ones only made things worse.
Fixes: 1,485
Have you tried plugging your router into the test socket and see if that makes any difference?
vespy
we've had it plugged into the test socket for  well over a year now, due to dodgy wiring around the other sockets.
Simonzo
Hi vespy, do you have your xbox or pc/laptop wired to your router or do you use wireless?
