Playstation 4 common problem with Plusnet?
- Gaming
- Re: Playstation 4 common problem with Plusnet?
21-05-2015 6:53 PM
Primary DNS = 8.8.8.8
Secondary DNS = 8.8.4.4
21-05-2015 7:39 PM
21-05-2015 9:59 PM
22-05-2015 12:53 AM
Once logged in -
To set up a Static address, on the LH menu, select DHCP Server then select Address Reservation.
Enter the required information - page 45 para.4.6.3 of the manual refers. You may need to click refresh. Note the chosen IP address must be within the defined DHCP Server range. (see DHCP Settings para.4.6.1 in the manual).
To set up DMZ, on the LH menu, select Forwarding, then select DMZ. Select Enable and enter the chosen IP address for the chosen console. Click Save. See p82 para.4.13.3 in the manual.
uPnP is the next item in the LH menu if you require it. Click Enable if necessary. See para.4.13.4 in the manual.
HTH.
22-05-2015 11:18 AM
22-05-2015 11:35 AM
22-05-2015 12:38 PM
Which IP address shall I use?
I cannot use these ranges below that member Mook posted earlier?:
192.168.1.2 > 192.168.1.99
192.168.1.200 > 192.168.1.253
22-05-2015 12:49 PM
Quote from: very452001 I inputted 192.168.1.222 IP address into my PS4, Is this IP address out of the DHCP Server Range?
This one will be fine. Does it now work as you hope?
22-05-2015 12:58 PM
22-05-2015 1:01 PM
As the address is still within the range of your LAN's network it will still work.
22-05-2015 1:54 PM
In or Out?
22-05-2015 2:28 PM
So here's a thought, you can :
Follow my instructions without the Reservation or DMZ using an IP address outside of the DHCP range such as 192.168.1.222.
If this doesn't work for you then
Follow AnotherOne's instructions and set up the Address Reservation and DMZ using an address in the DHCP range ( such as 192.168.1.100) then modify the PS4's static IP to match the address you reserved.
I hope this makes more sense to you now.
22-05-2015 4:53 PM
22-05-2015 6:55 PM
Hope in the future it will be plug and play instead of complex manual entry. I wonder how the newbie beginner customers are coping with online gaming via plusnet?
22-05-2015 7:38 PM
