PS3 NAT Type 3
- Gaming
- PS3 NAT Type 3
PS3 NAT Type 3
25-01-2011 2:51 PM
Hi
Sorry if this has been asked before, I am new and had PLUS net go live today
Trying to connect my PS3 but it has NAT type 3
How can I change this to NAT type 2
Again, sorry if thsi ahs been asked before
Dick:blue All caps title edited as per forum rules.
6 REPLIES 6
Re: PS3 NAT Type 3
25-01-2011 3:00 PM
Welcome to the forum sparky2005
Have a look at this thread for starters.
Re: PS3 NAT Type 3
25-01-2011 3:09 PM
that was a quick reply, thank you
yea, it worked, I enabled UPnP and now have NAT TYPE 2
will see how it goes
Thank you
Thank you
Re: PS3 NAT Type 3
30-01-2011 7:36 PM
I'm having the same problem. I'm trying to change my NAT type from 3 to 2 so that I can use voice comms in games.. I set the PS3 IP address as static and forwarded the PS3 ports but on the internet connection settings screen on the ps3 it says UPnP not enabled. How do I fix this ?
Re: PS3 NAT Type 3
30-01-2011 9:01 PM
On the PS3 chose 'Internet Connection Settings'
On 'Select a Setting Method' chose 'Custom'.
Work your way through the settings until you come to 'UPnP' which should be set to 'Enable'. If not change it.
Re: PS3 NAT Type 3
15-02-2011 2:02 AM
My own PS3 has uPNP enabled and NAT type 2...so far so good.
Now I play Black Ops and it tells me my NAT is Moderate and that I might lose connections....which I occasionally do.
So I gave my PS3 a static IP and stuck it in the DMZ (something I don't like doing).
Now Black OPs tells me my NAT is Open so I will see how things go.
Someone on an AV forum suggested putting MW2 in first, taking it out and putting Black Ops in as an alternative to the above.
Re: PS3 NAT Type 3
25-02-2011 10:19 PM
Everytime i try to go online with my PS3 all i get is router too strick please help.
I am not a person that understands ip and statics so if you could help me could you please tell me
exactly what i need to put if i need to put numbers in etc, i sure do hope some one could help me.
I have had plusnet for over 2 months and still struggling to get online with my PS3
Thank you to anyone who can help
Dawn x
