TDU2- setting router to allow ports on PC?
laserguy
Hi, I have tried to forward the ports on my thomson router but can't get the TDU2 launcher to give me a green light. I am getting the response of Strict:Symetric, uPnP is on. I have tried to configure the router as such:
Protocol Port Range Translate To ... Trigger Protocol Trigger Port
TCP 8889 - 8889 8889 - 8889 TCP 8889
UDP 8889 - 8889 8889 - 8889 UDP 8889
TCP 3478 - 3478 3478 - 3478 TCP 3478
UDP 3478 - 3478 3478 - 3478 TCP 3478
using the advise of this guide:
http://forums.testdriveunlimited2.com/showthread.php?p=212112
I don't know what I am doing wrong? Do I need static IP? Isn't that what uPnP is meant to do? Have I got something else wrong?
sry, this is on the supplied thomson TG686v8
