PS3 - Burnout Paradise network issues.
- Gaming
- PS3 - Burnout Paradise network issues.
- « Previous
- 1
- 2
- Next »
Re: PS3 - Burnout Paradise network issues.
28-03-2008 10:10 PM
Quote from: _CN_
Quote from: mk2cav the game connects to the server on port 3658 and runs voip on port 6000
Like I said it also uses two other TCP ports, the actual traffic between players (peer2peer) is UDP 3659
Regards
Carl
PM sent.
31-03-2008 12:12 AM
Had the most entertaining weekend playing burnout paradise online with no glitches. Heres hopeing you can fix it permanent at your end.
31-03-2008 5:43 PM
Quote from: mk2cav Thanks Carl,
Great!!!! Our Net Ops team have picked up the changes required so should be a permanent fix pretty soon, I'll keep you up-to-date
Carl
04-04-2008 3:20 PM
Quote from: _CN_ Our Net Ops team have picked up the changes required so should be a permanent fix pretty soon, I'll keep you up-to-date
The Net Ops team made these changes yesterday and you were moved off the temp fix, hopefully things have been continuing to work!
Regards
Carl
06-04-2008 7:23 PM
Inital results are not looking good 6pm sunday, 1st time ive had a chance to play it at peak times. Very long delays connecting to server. Will not connect to the other players when I can finaly get into a game.
As you are aware this game is seen as peer to peer traffic so looks like there might still be problems with the network. I will try again later and let you know how I get on.
I am now at 101% and got all 350 online challanges
07-04-2008 9:21 AM
I've let Carl know that you've replied here.
07-04-2008 9:29 AM
Carl wants to look at the traffic on your line and needs to know specifically when you'll be starting up your gaming sessions with no other traffic occurring on your network.
07-04-2008 2:19 PM
My ps3 ID is mk2cav
I can ensure that there is no other traffic on my network.
Can make it any time that suits Carl. I will be on at 7pm.
Thanks for all the help, it is appreciated.
Regards
07-04-2008 2:21 PM
I'd drop Carl a PM so that you and he can discuss specific timings as apparently it needs to be rather exact so that he knows exactly what to look for.
He does suspect that it may be NAT/Forwarding related.
07-04-2008 2:24 PM
The NAT/Forwarding issue doesnt make sense because it was all working perfectly last week when I had no restrictions, unless its a NAT/Forwarding issue at your end.
Thanks.
Moderators note by James_H : Removed full quote of previous post - it is not needed in this situation.
07-04-2008 2:31 PM
Quote from: mk2cav The NAT/Forwarding issue doesnt make sense because it was all working perfectly last week when I had no restrictions, unless its a NAT/Forwarding issue at your end.
Its more about NAT/restrictive firewalls in that there are other ports used to facilitate the game connection, my PS3 is No-NAT, DMZ (non-restrictive) firewall.
Carl
08-04-2008 10:56 AM
Moderators note by James_H : Shortened URL - auto shortening didn't work for some reason, suspect *'s in the URL confuddled it somewhat.
09-04-2008 10:43 AM
- « Previous
- 1
- 2
- Next »
