Lag/ping problem
- Gaming
- Lag/ping problem
Lag/ping problem
17-01-2008 8:24 PM
Re: Lag/ping problem
17-01-2008 9:03 PM
31-01-2008 8:49 AM
If I renew my IP address on the router - it goes fast again for a couple of mins then goes slow.
The strange thing is this seems to have started occuring since PlusNet brought out the gaming package which I am not on.
Could it be because they are detecting this and my traffic is getting severly downgraded?
31-01-2008 10:40 AM
If you use something called Wireshark, you can identify how your traffic is being prioritsed.
http://www.plus.net/support/broadband/troubleshooting/wireshark_video.shtml
01-02-2008 2:38 PM
The slowdown does seem erratic. Can go a couple of days without it happening, then it will do it for a few days in a row.
I will do a wireshark capture tonight.
01-02-2008 4:43 PM
Quote from: Jameseh Hi Ian,
I have noticed this as well playing BF2142. Recently I keep getting lag spikes of up to 500ms on some servers which were previously fine at peak times. Also when pinging bbc.co.uk at peak time it used to be stable at around 20ms and it now spikes up to 40ms or more if you leave a continious ping.
I am on the old premier 1 account and until recently gaming has been really stable with pings around 20ms on UK servers and stable pings on servers abroad. Now some UK servers have lag spikes and alot of ones abroad do for bf2142. This has a negative impact on gaming and if it keeps up for another month or so I will start looking for another ISP as my friends on different ISP's don't get the same issues on the servers I do. This does not affect all servers.
02-02-2008 8:11 AM
if you want to give it a go here is one of the servers which at the moment has a constant 16-20ms ping in game and is very stable. Last night during peaktime it kept lag spiking up to about 500ms which made the game unplayable. I have not had any issues at all until the last couple of months or so and it is not every server but just some but always the same ones. Everyone else on the server has normal pings. Below is an example.
BF2142
Money gamers squadplay
193.33.186.120:17567
Other people on the server last night did not get the high pings and lag spikes I was getting.
Hope that helps.
13-02-2008 4:40 PM
First there whould be no lag whatsoever, then for a couple of hours the lag would be unbearable. After that it would clear again for no reason, then lag again. I know for a fact that it's not my PC [Q6600 Quad core CPU, 768Mb 8800 GTX, 4GB RAM, 10k RPM Raptors...], and at first I thought it may have been a problem with Wurm Online. The fact that the exact same issue happened in Regnum Online leads me to believe that it has to be an issue with PlusNet.
I submitted the details of both the gaming servers to PlusNet.
Not sure if it means anything, but i'm also on the old Premier 1 package.
24-02-2008 8:37 PM
I am also Old Premier 1 customer ( For over two years now ). Thinks about looking for better service ? Plusnet has been good but needs to stay that way to keep customers.
At least I am not alone
24-02-2008 8:38 PM
Is "Wireshark" useful for consoles or can it only be used with PC's?
02-03-2008 10:36 PM
It wont help in this case because once you run an OS you can't run the Game.
Only way around that would be:
a HUB connected in conjunction to your ADSL on LAN,
intercepting packets over the LAN on the HUB with a PC,
(it doesn't operate like a Switch does, it braudcasts packets instead of routing them)
Hope that can get you somewhere.
Jim,
26-03-2008 11:03 PM
27-03-2008 9:44 AM
We've had some network balance problems recently, notably when BT dropped one of our centrals. Balance should come back naturally over the next few days, which should hopefully result in your lag improving.
27-03-2008 10:44 AM
10-04-2008 7:21 PM
Are PN trying to get rid of the old Prem 1 accounts because our off peak (free) usage is 16 hours a day not 8 as in the new deals.
Never used to have problems like this until the "Gaming" BBYWP started, looks like the people who have been loyal to PN are now second class.
