Lag during peak times
- Gaming
- Lag during peak times
- « Previous
- Next »
Re: Lag during peak times
30-09-2009 9:47 PM
Quote from: Bob Have raised an internal problem so we can get some investigation underway (ref: 58439).
Not convinced it's a DNS issue especially in light of Steve's comments and some of the traceroute which seem to be timing out at the hop where the traffic management switches are. We did a quick health check on these yesterday and couldn't spot anything glaringly obvious but I guess we may have missed something.
There seems to be a few too many reports of problems here for something not to be wrong
30-09-2009 9:54 PM
Quote from: Barry Interim high pings, which are followed by low pings are not *usually* a cause for concern - it means that the router is doing 'more important' things than responding to pings (like routing traffic).
When doing a tracert, if there is a router where pings elevate substantially, and all following pings are also high then that may indicate a problem.
That being said, it does seem like your pings are not stable, and the fingers are pointing to backhaul contention. It seems like you are on ADSL and *may* benefit from ADSL2+ (the backhauls are different) so perhaps that is an option?
B.
Well for most people this wouldn't be a concern, most people wouldn't even notice. But being a gamer any flux in ping time is noticed by me and when it's as bad as it currently is it makes gaming a nightmare.
ADSL2+ is not avaible here and according to BT it won't be installed at my exchange until Q4 2011....
01-10-2009 8:43 PM
Not happy.
02-10-2009 3:47 PM
02-10-2009 3:50 PM
Can you set off a constant ping? (I can't remember the exact command but someone else here will).
I'd like to see if you're actually dropping packets.
02-10-2009 3:52 PM
ping -t <hostname / ip address>
You'll need to press CTRL-C to end the pinging-spree that ensues!
02-10-2009 3:52 PM
02-10-2009 4:38 PM
Pings are stable atm, heres a constant ping:
Pinging 212.159.6.211 with 32 bytes of data:
Reply from 212.159.6.211: bytes=32 time=43ms TTL=58
Reply from 212.159.6.211: bytes=32 time=41ms TTL=58
Reply from 212.159.6.211: bytes=32 time=40ms TTL=58
Reply from 212.159.6.211: bytes=32 time=39ms TTL=58
Reply from 212.159.6.211: bytes=32 time=42ms TTL=58
Ping statistics for 212.159.6.211:
Packets: Sent = 36, Received = 36, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 39ms, Maximum = 43ms, Average = 39ms
02-10-2009 5:48 PM
Reply from 212.159.6.211: bytes=32 time=40ms TTL=61
Reply from 212.159.6.211: bytes=32 time=41ms TTL=61
Reply from 212.159.6.211: bytes=32 time=60ms TTL=61
Reply from 212.159.6.211: bytes=32 time=47ms TTL=61
Reply from 212.159.6.211: bytes=32 time=45ms TTL=61
Reply from 212.159.6.211: bytes=32 time=50ms TTL=61
Reply from 212.159.6.211: bytes=32 time=69ms TTL=61
Reply from 212.159.6.211: bytes=32 time=48ms TTL=61
Reply from 212.159.6.211: bytes=32 time=42ms TTL=61
Reply from 212.159.6.211: bytes=32 time=44ms TTL=61
Reply from 212.159.6.211: bytes=32 time=54ms TTL=61
Reply from 212.159.6.211: bytes=32 time=43ms TTL=61
Reply from 212.159.6.211: bytes=32 time=49ms TTL=61
Reply from 212.159.6.211: bytes=32 time=62ms TTL=61
Reply from 212.159.6.211: bytes=32 time=89ms TTL=61
Reply from 212.159.6.211: bytes=32 time=39ms TTL=61
Packets: Sent = 29, Received = 29, Lost = 0 (0% loss),
Minimum = 39ms, Maximum = 89ms, Average = 49ms
Control-C
12-10-2009 9:18 PM
I'm shocked how bad plus.net is. You claim gaming traffic is prioritsed....low ping ect ect....all lies....you can't even provide a stable ping let alone a low one. I don't care where the problem lies, I pay plus.net my hard earned money so I expect plus.net to fix the problem.
No doubt I'm stuck in a 18 month contract. So carry on taking my money and provide me with a sub-standard connection.
Thanks.
12-10-2009 9:22 PM
12-10-2009 11:31 PM
22:02 12/Oct/2009 0:14:46
21:47 12/Oct/2009 0:34:6
21:12 12/Oct/2009 0:1:14
21:11 12/Oct/2009 0:23:38
20:46 12/Oct/2009 7:9:54
@mad4rangers, yours is even worse
22:48 12/Oct/2009 0:0:34
22:46 12/Oct/2009 0:1:17
22:43 12/Oct/2009 0:1:30
22:41 12/Oct/2009 1:4:12
21:35 12/Oct/2009 0:1:23
21:32 12/Oct/2009 0:30:40
21:00 12/Oct/2009 0:1:58
20:57 12/Oct/2009 0:1:17
20:54 12/Oct/2009 0:2:18
20:51 12/Oct/2009 0:2:48
20:47 12/Oct/2009 0:1:0
20:44 12/Oct/2009 0:1:59
20:41 12/Oct/2009 0:0:48
20:39 12/Oct/2009 0:0:52
20:37 12/Oct/2009 0:1:28
20:34 12/Oct/2009 1:17:7
19:15 12/Oct/2009 0:8:2
19:06 12/Oct/2009 0:8:36
18:56 12/Oct/2009 0:8:13
18:46 12/Oct/2009 0:0:46
18:44 12/Oct/2009 0:1:52
18:41 12/Oct/2009 3:55:34
14:44 12/Oct/2009 0:11:27
04:56 12/Oct/2009 10:0:30
12-10-2009 11:44 PM
Needless to say it didn't work.
13-10-2009 7:54 AM
Just been into WOW now and got 46-129 ping which is 50% lower then it is come 6pm, I have managed to play the PS3 lag free in the day so what ever my issue is it starts in the evenings.
Will try and get wireshark working today.
- « Previous
- Next »
