Lag during peak times
Oldjim
Resting Legend
Fixes: 63
Re: Lag during peak times
It is more likely this problem
Quote from: Bob
Have raised an internal problem so we can get some investigation underway (ref: 58439).
Not convinced it's a DNS issue especially in light of Steve's comments and some of the traceroute which seem to be timing out at the hop where the traffic management switches are. We did a quick health check on these yesterday and couldn't spot anything glaringly obvious but I guess we may have missed something.
There seems to be a few too many reports of problems here for something not to be wrong Sad
mad4rangers
Quote from: Barry
Interim high pings, which are followed by low pings are not *usually* a cause for concern - it means that the router is doing 'more important' things than responding to pings (like routing traffic).
When doing a tracert, if there is a router where pings elevate substantially, and all following pings are also high then that may indicate a problem.
That being said, it does seem like your pings are not stable, and the fingers are pointing to backhaul contention.    It seems like you are on ADSL and *may* benefit from ADSL2+ (the backhauls are different) so perhaps that is an option?
B.
Well for most people this wouldn't be a concern, most people wouldn't even notice. But being a gamer any flux in ping time is noticed by me and when it's as bad as it currently is it makes gaming a nightmare.
ADSL2+ is not avaible here and according to BT it won't be installed at my exchange until Q4 2011.... Sad
mad4rangers
Guess I'm stuck with this problem then? £28 a month and I can't even play quake at tea time.
Not happy.
James
Not necessarily.  I'm going to try something.
James
Nope, that won't work, you're already on Max Premium Sad
Can you set off a constant ping? (I can't remember the exact command but someone else here will).
I'd like to see if you're actually dropping packets.
SparckZero
The command for constant pinging is:
ping -t <hostname / ip address>
You'll need to press CTRL-C to end the pinging-spree that ensues! Smiley
Strat
Fixes: 565
Curses...beat me Angry
mad4rangers
Don't think I'm dropping packets because packetloss is shown on the lagometer in quake 3 as big red lines and I haven't seen any.
Pings are stable atm, heres a constant ping:
Pinging 212.159.6.211 with 32 bytes of data:
Reply from 212.159.6.211: bytes=32 time=43ms TTL=58
Reply from 212.159.6.211: bytes=32 time=41ms TTL=58
Reply from 212.159.6.211: bytes=32 time=40ms TTL=58
Reply from 212.159.6.211: bytes=32 time=39ms TTL=58
Reply from 212.159.6.211: bytes=32 time=42ms TTL=58
Ping statistics for 212.159.6.211:
    Packets: Sent = 36, Received = 36, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 39ms, Maximum = 43ms, Average = 39ms
mad4rangers
And now with lag.
Reply from 212.159.6.211: bytes=32 time=40ms TTL=61
Reply from 212.159.6.211: bytes=32 time=41ms TTL=61
Reply from 212.159.6.211: bytes=32 time=60ms TTL=61
Reply from 212.159.6.211: bytes=32 time=47ms TTL=61
Reply from 212.159.6.211: bytes=32 time=45ms TTL=61
Reply from 212.159.6.211: bytes=32 time=50ms TTL=61
Reply from 212.159.6.211: bytes=32 time=69ms TTL=61
Reply from 212.159.6.211: bytes=32 time=48ms TTL=61
Reply from 212.159.6.211: bytes=32 time=42ms TTL=61
Reply from 212.159.6.211: bytes=32 time=44ms TTL=61
Reply from 212.159.6.211: bytes=32 time=54ms TTL=61
Reply from 212.159.6.211: bytes=32 time=43ms TTL=61
Reply from 212.159.6.211: bytes=32 time=49ms TTL=61
Reply from 212.159.6.211: bytes=32 time=62ms TTL=61
Reply from 212.159.6.211: bytes=32 time=89ms TTL=61
Reply from 212.159.6.211: bytes=32 time=39ms TTL=61
    Packets: Sent = 29, Received = 29, Lost = 0 (0% loss),
    Minimum = 39ms, Maximum = 89ms, Average = 49ms
Control-C
mad4rangers
Well still getting this problem, and it's alot worse now...150ms+ pings at peak time. Phone up the support line and noone even has a clue what I'm going on about.
I'm shocked how bad plus.net is. You claim gaming traffic is prioritsed....low ping ect ect....all lies....you can't even provide a stable ping let alone a low one. I don't care where the problem lies, I pay plus.net my hard earned money so I expect plus.net to fix the problem.
No doubt I'm stuck in a 18 month contract. So carry on taking my money and provide me with a sub-standard connection.
Thanks.
goberpiles
I always have a 250ms ping in WOW on the PC, I cant play online games using my PS3 because it keeps kicking me because of lag, I am sick of it, had to give up Fifa 09 because it was unplayable now seems I have to put up with the same on Fifa 10.
bobpullen
Fixes: 316
@goberpiles, you had a few disconnections around the time you posted, are you sure it wasn't these that caused your gaming lag/connectivity issues?
22:02 12/Oct/2009	  0:14:46
21:47 12/Oct/2009   0:34:6
21:12 12/Oct/2009   0:1:14
21:11 12/Oct/2009   0:23:38
20:46 12/Oct/2009   7:9:54
@mad4rangers, yours is even worse Sad
22:48 12/Oct/2009	  0:0:34
22:46 12/Oct/2009   0:1:17
22:43 12/Oct/2009   0:1:30
22:41 12/Oct/2009   1:4:12
21:35 12/Oct/2009   0:1:23
21:32 12/Oct/2009   0:30:40
21:00 12/Oct/2009   0:1:58
20:57 12/Oct/2009   0:1:17
20:54 12/Oct/2009   0:2:18
20:51 12/Oct/2009   0:2:48
20:47 12/Oct/2009   0:1:0
20:44 12/Oct/2009   0:1:59
20:41 12/Oct/2009   0:0:48
20:39 12/Oct/2009   0:0:52
20:37 12/Oct/2009   0:1:28
20:34 12/Oct/2009   1:17:7
19:15 12/Oct/2009   0:8:2
19:06 12/Oct/2009   0:8:36
18:56 12/Oct/2009   0:8:13
18:46 12/Oct/2009   0:0:46
18:44 12/Oct/2009   0:1:52
18:41 12/Oct/2009   3:55:34
14:44 12/Oct/2009   0:11:27
04:56 12/Oct/2009   10:0:30
mad4rangers
Well I can explain my disconnects...I thought I would keep restarting my router to try differen't gateways. lol
Needless to say it didn't work.
goberpiles
My disconnections were me rebooting router to remove it from dmz, changing thr router to the [Censored] one you provided, and when I still had lag back to my Netgear router, no matter what I use I lag like hell on the Playstation 3 online.
Just been into WOW now and got 46-129 ping which is 50% lower then it is come 6pm, I have managed to play the PS3 lag free in the day so what ever my issue is it starts in the evenings.
Will try and get wireshark working today.
