Just joined Plusnet
- Gaming
- Re: Just joined Plusnet
Just joined Plusnet
20-11-2009 12:23 AM
Im now getting pings from 50 - 70 is this normal? Has this got something to do with this interleaving thing?
Hope someone can help
Glenn.
20-11-2009 7:46 AM
I think my ping was about 50 before I switched it off.
20-11-2009 12:17 PM
When i run cmd ping -t tests or tracerts I get around a 20-50 ms ping, but ingame on MW2 im normally 3 bar not 4..
20-11-2009 12:20 PM
You can raise a ticket to have it turned off.
20-11-2009 12:44 PM
20-11-2009 12:59 PM
20-11-2009 1:01 PM
20-11-2009 1:33 PM
20-11-2009 5:28 PM
Glenn.
Re:Just joined Plusnet
23-11-2009 10:17 PM
Turning off interleaving should help.
If you want this done, either raise a ticket or shout up here and we'll sort it for you.
23-11-2009 11:51 PM
Quote from: Mand Hi there,
i thought interleaving was off by default on new pro connections?
i'm also a new pro user (few days in) and when i called support to check interleaving status the guy told me all pro users are automatically put on fastpath.
24-11-2009 12:37 AM
what router do you have and we can point you where to look for the interleaving status of your line.
if your using the PN thomson 585v7 then follow this guide here http://community.plus.net/forum/index.php/topic,80792.msg659208.html#msg659208
even if it comes back as fastpath it could mean your on auto, so it still be helpful for one of the comms to double check this for you
worth noting the cs agents names when you have dealings with them so if you do get told complete wrong info that they should really know you can pass there names on to the forum comms team ie mand, so they can go inforce a wee bit of knowledge on them.
p.s dont post there name publicly on the forum thoe as this agaisnt forum rules
24-11-2009 1:25 AM
