Gaming Issues Latency/Ping
cmlcoughlin91
Re: Gaming Issues Latency/Ping
@Kelly Apologies, I'm at work at the moment, so will have to wait until ~6pm to do any testing. I can update you later?
Kelly
Fixes: 9
Yep.  No problems.
Kelly Dorset
Ex-Broadband Service Manager
cmlcoughlin91
Hi @Kelly, no change. I joined my first game with 500ms latency and was booted from it about a minute later.
MrSilver
Fixes: 9
Can you try just a simple ping in a dos box?
ping pingbox1.thinkbroadband.com
Ping -l 1300 pingbox1.thinkbroadband.com
tracert pingbox1.thinkbroadband.com
and finally
ping 192.168.1.254
thanks
cmlcoughlin91
Sure I've just done this. Results:
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Users\Chris>ping pingbox1.thinkbroadband.com
Pinging pingbox1.thinkbroadband.com [80.249.99.164] with 32 bytes of data:
Reply from 80.249.99.164: bytes=32 time=8ms TTL=56
Ping statistics for 80.249.99.164:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 8ms, Maximum = 8ms, Average = 8ms
C:\Users\Chris>Ping -l 1300 pingbox1.thinkbroadband.com
Pinging pingbox1.thinkbroadband.com [80.249.99.164] with 1300 bytes of data:
Reply from 80.249.99.164: bytes=1300 time=75ms TTL=56
Reply from 80.249.99.164: bytes=1300 time=19ms TTL=56
Reply from 80.249.99.164: bytes=1300 time=83ms TTL=56
Minimum = 19ms, Maximum = 83ms, Average = 49ms
C:\Users\Chris>tracert pingbox1.thinkbroadband.com
Tracing route to pingbox1.thinkbroadband.com [80.249.99.164]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
2 8 ms 7 ms 8 ms lo0.central10.pcn-bng01.plus.net [195.166.130.248]
3 8 ms 8 ms 9 ms 411.be5.pcn-ir02.plus.net [84.93.253.71]
4 8 ms 8 ms 8 ms 195.99.125.140
5 9 ms 8 ms 9 ms peer6-hu0-7-0-0.telehouse.ukcore.bt.net [62.172.103.15]
6 * * * Request timed out.
7 73 ms 21 ms 146 ms te2-1-9.star10g.bdr-rt3.thdo.ncuk.net [80.249.97.17]
8 13 ms 10 ms 17 ms po4-31.core-rs2.thdo.ncuk.net [80.249.97.85]
9 77 ms 50 ms 30 ms pingbox1.thinkbroadband.com [80.249.99.164]
Trace complete.
C:\Users\Chris>ping 192.168.1.254
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time<1ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1ms TTL=64
Ping statistics for 192.168.1.254:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\Users\Chris>
Kelly
Fixes: 9
Can you do some longer pings?   -n5000 or something, just so we can see if it's consistent?
Kelly Dorset
cmlcoughlin91
@Kelly sorry for my incompetence, but it would it be possible to format what I need to type into 'cmd' similar to how @MrSilver has done above? I'm not too familiar with this...Many thanks.
@cmlcoughlin91 - I assume he means :
ping -n 5000 192.168.1.254
This will do 5000 ping then stop automatically.
cmlcoughlin91
@Anonymous thanks! Smiley
MrSilver
Fixes: 9
You can also add -t instead to run for ever, then press ctrl c to stop and get stats.
Good news is most of the tests look relatively normal, but high at the end of the traceroute one.
What game are you playing and do you know the ip or name of the server?
cmlcoughlin91
Hi All, my results are as seen below and seem normal (I think)??? The game that I am running these tests against is Rainbow Six Siege (PC) on the Western Europe server and unfortunately I can't find the server IP, but as mentioned previously, this also affects all games on my Xbox too..
Whilst running the below tests, I was kicked from two games whilsts running with ~250-300ms ping in each.
Results:
C:\Users\Chris>ping -n 5000 192.168.1.254
Reply from 192.168.1.254: bytes=32 time=64ms TTL=64
Reply from 192.168.1.254: bytes=32 time=3ms TTL=64
Reply from 192.168.1.254: bytes=32 time=12ms TTL=64
Reply from 192.168.1.254: bytes=32 time=24ms TTL=64
Reply from 192.168.1.254: bytes=32 time=15ms TTL=64
Reply from 192.168.1.254: bytes=32 time=7ms TTL=64
Reply from 192.168.1.254: bytes=32 time=9ms TTL=64
Reply from 192.168.1.254: bytes=32 time=6ms TTL=64
Reply from 192.168.1.254: bytes=32 time=61ms TTL=64
Reply from 192.168.1.254: bytes=32 time=18ms TTL=64
Reply from 192.168.1.254: bytes=32 time=10ms TTL=64
Reply from 192.168.1.254: bytes=32 time=2ms TTL=64
Packets: Sent = 634, Received = 634, Lost = 0 (0% loss),
Minimum = 0ms, Maximum = 64ms, Average = 0ms
Control-C
MrSilver
Fixes: 9
Can you try In both Casual and Terrorist Hunt game modes, as well as ranked? Is it the same latency in all?
I've seen reports of 500ms in ranked games but fine in causal and terrorist. May help narrow down.
cmlcoughlin91
Ok, so the first set of results were from a casual game, as have all my previous tests been. This was one of the lowest ping games I've experienced in a while (60-80ms compared to one hour ago of 300ms), but rubber banding still seemed somewhat present.
The second set of results were from a game of terrorist hunt which I experienced the much more normal ping of 200ms+.
Unfortunately I can't post a ranked option, as I'm only level 15 at the moment.
Results:
Reply from 192.168.1.254: bytes=32 time=39ms TTL=64
Reply from 192.168.1.254: bytes=32 time=31ms TTL=64
Reply from 192.168.1.254: bytes=32 time=34ms TTL=64
Reply from 192.168.1.254: bytes=32 time=8ms TTL=64
Reply from 192.168.1.254: bytes=32 time=11ms TTL=64
Reply from 192.168.1.254: bytes=32 time=4ms TTL=64
Reply from 192.168.1.254: bytes=32 time=26ms TTL=64
Reply from 192.168.1.254: bytes=32 time=25ms TTL=64
Reply from 192.168.1.254: bytes=32 time=5ms TTL=64
Reply from 192.168.1.254: bytes=32 time=60ms TTL=64
Reply from 192.168.1.254: bytes=32 time=49ms TTL=64
Reply from 192.168.1.254: bytes=32 time=37ms TTL=64
Packets: Sent = 641, Received = 641, Lost = 0 (0% loss),
Minimum = 0ms, Maximum = 60ms, Average = 0ms
Control-C
^C
cmlcoughlin91
Terrorist Hunt Results:
Reply from 192.168.1.254: bytes=32 time=14ms TTL=64
Reply from 192.168.1.254: bytes=32 time=35ms TTL=64
Reply from 192.168.1.254: bytes=32 time=23ms TTL=64
Packets: Sent = 381, Received = 381, Lost = 0 (0% loss),
Minimum = 0ms, Maximum = 49ms, Average = 0ms
Reply from 192.168.1.254: Control-C
^C
C:\Users\Chris>
Can I suggest that rather than paste the outcome of large ping runs in to the post body you could run the command like this:
ping -n 10 192.168.0.1 > ping.txt
This will create a text file called ping.txt with the results in it that you can then attach to the post like the one below. You could even name the file to reflect the name of the ping test you are doing.
