Gaming Issues Latency/Ping
- Gaming
- Re: Gaming Issues Latency/Ping
26-01-2017 11:50 AM - edited 26-01-2017 11:51 AM
@Kelly Apologies, I'm at work at the moment, so will have to wait until ~6pm to do any testing. I can update you later?
26-01-2017 11:52 AM
Yep. No problems.
Ex-Broadband Service Manager
26-01-2017 6:13 PM
Hi @Kelly, no change. I joined my first game with 500ms latency and was booted from it about a minute later.
26-01-2017 6:56 PM
Can you try just a simple ping in a dos box?
ping pingbox1.thinkbroadband.com
Ping -l 1300 pingbox1.thinkbroadband.com
tracert pingbox1.thinkbroadband.com
and finally
ping 192.168.1.254
thanks
26-01-2017 6:59 PM
Sure I've just done this. Results:
Microsoft Windows [Version 10.0.14393]
(c) 2016 Microsoft Corporation. All rights reserved.
C:\Users\Chris>ping pingbox1.thinkbroadband.com
Pinging pingbox1.thinkbroadband.com [80.249.99.164] with 32 bytes of data:
Reply from 80.249.99.164: bytes=32 time=8ms TTL=56
Ping statistics for 80.249.99.164:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 8ms, Maximum = 8ms, Average = 8ms
C:\Users\Chris>Ping -l 1300 pingbox1.thinkbroadband.com
Pinging pingbox1.thinkbroadband.com [80.249.99.164] with 1300 bytes of data:
Reply from 80.249.99.164: bytes=1300 time=75ms TTL=56
Reply from 80.249.99.164: bytes=1300 time=19ms TTL=56
Reply from 80.249.99.164: bytes=1300 time=83ms TTL=56
Minimum = 19ms, Maximum = 83ms, Average = 49ms
C:\Users\Chris>tracert pingbox1.thinkbroadband.com
Tracing route to pingbox1.thinkbroadband.com [80.249.99.164]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms dsldevice.lan [192.168.1.254]
2 8 ms 7 ms 8 ms lo0.central10.pcn-bng01.plus.net [195.166.130.248]
3 8 ms 8 ms 9 ms 411.be5.pcn-ir02.plus.net [84.93.253.71]
4 8 ms 8 ms 8 ms 195.99.125.140
5 9 ms 8 ms 9 ms peer6-hu0-7-0-0.telehouse.ukcore.bt.net [62.172.103.15]
6 * * * Request timed out.
7 73 ms 21 ms 146 ms te2-1-9.star10g.bdr-rt3.thdo.ncuk.net [80.249.97.17]
8 13 ms 10 ms 17 ms po4-31.core-rs2.thdo.ncuk.net [80.249.97.85]
9 77 ms 50 ms 30 ms pingbox1.thinkbroadband.com [80.249.99.164]
Trace complete.
C:\Users\Chris>ping 192.168.1.254
Pinging 192.168.1.254 with 32 bytes of data:
Reply from 192.168.1.254: bytes=32 time<1ms TTL=64
Reply from 192.168.1.254: bytes=32 time=1ms TTL=64
Ping statistics for 192.168.1.254:
Minimum = 0ms, Maximum = 1ms, Average = 0ms
C:\Users\Chris>
27-01-2017 3:18 PM
Can you do some longer pings? -n5000 or something, just so we can see if it's consistent?
27-01-2017 3:28 PM - edited 27-01-2017 3:29 PM
27-01-2017 3:38 PM - edited 27-01-2017 4:08 PM
@cmlcoughlin91 - I assume he means :
ping -n 5000 192.168.1.254
This will do 5000 ping then stop automatically.
27-01-2017 3:56 PM
@Anonymous thanks!
27-01-2017 6:48 PM
Good news is most of the tests look relatively normal, but high at the end of the traceroute one.
What game are you playing and do you know the ip or name of the server?
27-01-2017 8:57 PM
Hi All, my results are as seen below and seem normal (I think)??? The game that I am running these tests against is Rainbow Six Siege (PC) on the Western Europe server and unfortunately I can't find the server IP, but as mentioned previously, this also affects all games on my Xbox too..
Whilst running the below tests, I was kicked from two games whilsts running with ~250-300ms ping in each.
Results:
C:\Users\Chris>ping -n 5000 192.168.1.254
Reply from 192.168.1.254: bytes=32 time=64ms TTL=64
Reply from 192.168.1.254: bytes=32 time=3ms TTL=64
Reply from 192.168.1.254: bytes=32 time=12ms TTL=64
Reply from 192.168.1.254: bytes=32 time=24ms TTL=64
Reply from 192.168.1.254: bytes=32 time=15ms TTL=64
Reply from 192.168.1.254: bytes=32 time=7ms TTL=64
Reply from 192.168.1.254: bytes=32 time=9ms TTL=64
Reply from 192.168.1.254: bytes=32 time=6ms TTL=64
Reply from 192.168.1.254: bytes=32 time=61ms TTL=64
Reply from 192.168.1.254: bytes=32 time=18ms TTL=64
Reply from 192.168.1.254: bytes=32 time=10ms TTL=64
Reply from 192.168.1.254: bytes=32 time=2ms TTL=64
Packets: Sent = 634, Received = 634, Lost = 0 (0% loss),
Minimum = 0ms, Maximum = 64ms, Average = 0ms
Control-C
27-01-2017 9:06 PM
I've seen reports of 500ms in ranked games but fine in causal and terrorist. May help narrow down.
27-01-2017 10:23 PM
Ok, so the first set of results were from a casual game, as have all my previous tests been. This was one of the lowest ping games I've experienced in a while (60-80ms compared to one hour ago of 300ms), but rubber banding still seemed somewhat present.
The second set of results were from a game of terrorist hunt which I experienced the much more normal ping of 200ms+.
Unfortunately I can't post a ranked option, as I'm only level 15 at the moment.
Results:
Reply from 192.168.1.254: bytes=32 time=39ms TTL=64
Reply from 192.168.1.254: bytes=32 time=31ms TTL=64
Reply from 192.168.1.254: bytes=32 time=34ms TTL=64
Reply from 192.168.1.254: bytes=32 time=8ms TTL=64
Reply from 192.168.1.254: bytes=32 time=11ms TTL=64
Reply from 192.168.1.254: bytes=32 time=4ms TTL=64
Reply from 192.168.1.254: bytes=32 time=26ms TTL=64
Reply from 192.168.1.254: bytes=32 time=25ms TTL=64
Reply from 192.168.1.254: bytes=32 time=5ms TTL=64
Reply from 192.168.1.254: bytes=32 time=60ms TTL=64
Reply from 192.168.1.254: bytes=32 time=49ms TTL=64
Reply from 192.168.1.254: bytes=32 time=37ms TTL=64
Packets: Sent = 641, Received = 641, Lost = 0 (0% loss),
Minimum = 0ms, Maximum = 60ms, Average = 0ms
Control-C
^C
27-01-2017 10:23 PM
Terrorist Hunt Results:
Reply from 192.168.1.254: bytes=32 time=14ms TTL=64
Reply from 192.168.1.254: bytes=32 time=35ms TTL=64
Reply from 192.168.1.254: bytes=32 time=23ms TTL=64
Packets: Sent = 381, Received = 381, Lost = 0 (0% loss),
Minimum = 0ms, Maximum = 49ms, Average = 0ms
Reply from 192.168.1.254: Control-C
^C
C:\Users\Chris>
28-01-2017 6:07 AM
Can I suggest that rather than paste the outcome of large ping runs in to the post body you could run the command like this:
ping -n 10 192.168.0.1 > ping.txt
This will create a text file called ping.txt with the results in it that you can then attach to the post like the one below. You could even name the file to reflect the name of the ping test you are doing.
