Final Fantasy XIV: Realm Reborn - Lag/Packet loss?
- Gaming
- Re: Final Fantasy XIV: Realm Reborn - Lag/Packet l...
Re: Final Fantasy XIV: Realm Reborn - Lag/Packet loss?
22-10-2013 9:18 PM
C:\Windows\system32>tracert 199.91.189.26
Tracing route to 199.91.189.26 over a maximum of 30 hops
1 <1 ms 2 ms <1 ms 192.168.1.254
2 89 ms 62 ms 32 ms lo0-central10.ptn-ag02.plus.net [195.166.128.191
3 15 ms 15 ms 14 ms link-a-central10.ptn-gw01.plus.net [212.159.2.13
2]
4 15 ms 14 ms 17 ms xe-1-2-0.ptw-cr01.plus.net [212.159.0.112]
5 15 ms 15 ms 15 ms te-4-2.car5.London1.Level3.net [217.163.45.249]
6 15 ms 16 ms 15 ms ae-51-51.csw1.London1.Level3.net [4.69.139.88]
7 15 ms 15 ms 15 ms ae-116-3502.edge3.London1.Level3.net [4.69.166.1
34]
8 15 ms 16 ms 15 ms ix-20-0.tcore1.LDN-London.as6453.net [195.219.83
.101]
9 105 ms 106 ms 106 ms if-17-2.tcore1.L78-London.as6453.net [80.231.130
.129]
10 104 ms 105 ms 107 ms if-2-2.tcore2.L78-London.as6453.net [80.231.131.
1]
11 107 ms 104 ms 104 ms if-20-2.tcore2.NYY-NewYork.as6453.net [216.6.99.
13]
12 105 ms 133 ms 104 ms if-2-2.tcore2.MTT-Montreal.as6453.net [64.86.226
.13]
13 103 ms 104 ms 103 ms if-0-2.tcore1.MTT-Montreal.as6453.net [216.6.115
.89]
14 152 ms 113 ms 105 ms if-5-2.tcore1.W6C-Montreal.as6453.net [64.86.31.
6]
15 147 ms * 148 ms 66.198.96.50
16 107 ms 134 ms 117 ms 192.34.76.2
17 134 ms 132 ms 132 ms 199.91.189.234
18 131 ms 141 ms * 199.91.189.26
19 138 ms * 133 ms 199.91.189.26
Trace complete.
22-10-2013 9:25 PM
Quote from: Aesir I'm guessing the upstream peer you've been talking about is Level3 and they seem to bounce us around London before moving to the states with quite high latency. I'm surprised the route is so different, as I thought plus.net was owned by BT
BT own us, but we are a completely separate entity. I.e. our own network, datacentres etc.
Ex-Broadband Service Manager
22-10-2013 10:18 PM
Traza a 124.150.157.53 sobre caminos de 30 saltos como máximo.
1 33 ms 100 ms 94 ms dsldevice.lan [192.168.1.254]
2 11 ms 14 ms 21 ms lo0-central10.ptn-ag03.plus.net [195.166.128.192]
3 11 ms 12 ms 11 ms link-b-central10.ptn-gw02.plus.net [212.159.2.138]
4 13 ms 14 ms 12 ms xe-5-3-0.ptw-cr02.plus.net [212.159.0.110]
5 12 ms 11 ms 11 ms 10gigabitethernet5-1.core1.lon1.he.net [5.57.80.128]
6 88 ms 78 ms 79 ms 10gigabitethernet10-4.core1.nyc4.he.net [72.52.92.241]
7 147 ms 149 ms 142 ms 10gigabitethernet10-3.core1.lax1.he.net [72.52.92.226]
8 146 ms 146 ms 147 ms pacnet.10gigabitethernet2-3.core1.lax1.he.net [216.218.223.206]
9 255 ms 255 ms 259 ms ip-202-147-0-52.asianetcom.net [202.147.0.52]
10 259 ms 264 ms 257 ms gi1-0-0.gw1.nrt5.asianetcom.net [202.147.0.178]
11 259 ms 258 ms 258 ms squareco.asianetcom.net [203.192.149.210]
12 255 ms 256 ms 259 ms 61.195.56.129
13 260 ms 259 ms 260 ms 219.117.144.66
14 258 ms 265 ms 259 ms 219.117.144.53
15 265 ms 257 ms 259 ms 219.117.144.41
16 261 ms 258 ms 262 ms 219.117.147.190
17 262 ms 260 ms 260 ms 124.150.157.53
There is something weird between jumps 6 to 7, and 8 to 9.
22-10-2013 10:33 PM
Quote from: Kelly Can you get your friend to do a traceroute to the game server from the BT connection so we can see which route the traffic is taking? That may help.
Did the BT Trace Route help?
23-10-2013 1:42 AM
Tracing route to 199.91.189.45 over a maximum of 30 hops
1 <1 ms <1 ms <1 ms SkyRouter.Home [192.168.0.1]
2 * * * Request timed out.
3 19 ms 16 ms 15 ms ip-84-38-37-14.easynet.co.uk [84.38.37.14]
4 15 ms 15 ms 17 ms 027809a7.bb.sky.com [2.120.9.167]
5 11 ms 11 ms 11 ms ae3.lon10.ip4.tinet.net [77.67.74.93]
6 89 ms 89 ms 89 ms xe-1-3-0.mtl10.ip4.tinet.net [89.149.184.74]
7 89 ms 89 ms 89 ms ormuco-gw.ip4.tinet.net [216.221.156.110]
8 93 ms 89 ms 89 ms 192.34.76.2
9 89 ms 89 ms 89 ms 199.91.189.234
10 89 ms 89 ms 89 ms 199.91.189.45
Trace complete.
23-10-2013 9:01 AM
I have plenty of Pingplotter sample sets showing the packet loss, but I can't attach them.
23-10-2013 9:47 AM
Quote from: Finguz It seems painfully clear that Level3 are causing the packet loss evident in all of my traces, and have been for quite a while now
Are you seeing packet loss from the final hop? Or from hosts along the route. You only need to care if you are seeing loss from that last hop as the others could just be the host discarding the packets.
23-10-2013 9:47 AM
Quote from: shadowff6
I've got a network engineer having a quick look now. Thanks
23-10-2013 9:57 AM
Quote from: Kelly
Most of them at varying times, but it seems much worse on the hosts in-between. It shows on my TBB ping monitor too..
23-10-2013 11:47 AM
"ormuco-gw.ip4.tinet.net [216.221.156.110]"
From what I can tell, Ormuco are the ISP for Square Enix's montreal datacentre, and it looks like Tiscali have a gateway on that network via their Tinet network, which Sky and BT are using. Is there any way Plusnet could specify some BGP rule that would force game traffic for the Canadian data centre to go priorise tinet.net?
EDIT: For the people with issues on the JP centre, there was an announcement from SE: http://eu.finalfantasyxiv.com/lodestone/news/detail/88990d513327dc7cd7dd7de5c5d84cc4798b1647 ; Did the issue clear up?
23-10-2013 1:42 PM
Quote from: Finguz Most of them at varying times, but it seems much worse on the hosts in-between. It shows on my TBB ping monitor too..
Your ping monitor is showing packet loss between you and the TBB monitor. Nothing to do with FF. Could be that a general line instability could be causing your problems though
23-10-2013 2:22 PM
I suppose I could start a thread but my support ticket was added to your internal ticket ( 77436 ) so I haven't bothered so far.
Sorry for the confusion, I'll avoid posting in this thread again
23-10-2013 2:28 PM
23-10-2013 2:38 PM
23-10-2013 4:00 PM
- Gaming
