Using old Router as Bridge
John40131
Hi, I'm curremtly waiting for full Fibre to be connected to my property and as I have a Full Fibre router I was wondering if I can use the old router as a Bridge or Access point ... if so what are the user name and password to access this router ...
Regards John Marshall
4 REPLIES 4
mystreet1
Seasoned Pro
Fixes: 7
Re: Using old Router as Bridge
This post will help set it up as as AP
https://community.plus.net/t5/Tech-Help-Software-Hardware-etc/How-to-make-Plusnet-Hub-Two-an-access-...
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
@John40131
Which Hub are you referring to? When you say 'bridge mode' you are looking for a modem for your new router?
The Hub One does not support 'bridge mode' but the Hub two does.
To make revert a Hub two to a modem
Connect to the Hub Home page, navigate ->Home -->Advanced settings --->Broadband ---->Bridging -----> make enabled Yes.
The Hub Two lights will now be a pink/purple colour.
Connect any LAN port of the Hub to the WAN port of the router.
The router internet connection needs to be PPPoE, username is [email protected] using the members centre password. There is no requirement for a VLAN the Hub provides that.
RealAleMadrid
Fixes: 68
@Dan_the_Van  The op is expecting to get Full Fibre so bridge or modem mode does not apply,
The ONT is effectively the FTTP modem. I think the enquiry is about configuring a Plusnet hub to be a wireless access point.
@RealAleMadrid I
I did ask if they are looking to use a Hub as a modem, so they have the information if required, just trying to be helpful!
Yes I know all about ONT's thank you.
Edit: Waiting for Full Fibre suggests they are still using a stand alone modem or modem/router.
