FTTC to FTTP what happens on the day
cjags
Fixes: 4
My daughter currently has FTTC + landline and Plusnet hub2.
She is changing to FTTP with nolandline and has a visit  from openreach scheduled to do the FTTP install.
Will they also connect the FTTP box up to the Plusnet hub?
Does anything need to be done on the hub?
15 REPLIES 15
Fixes: 357
Re: FTTC to FTTP what happens on the day
They may do - depends on the installer - but it is easy enough to do it yourself, just means plugging an Ethernet  cable between the ONT and the red (WAN) port on the HUB.
Nothing needs doing on the Hub.
Fixes: 558
They SHOULD do. They should connect the ONT to a router and check its working. Make sure there's an ethernet cable available as the ONT isnt supplied with one.
No, once the DSL cable is disconnected and an ethernet cable connected from the WAN (red) port to the ONT it should autodetect the new connection and just work.
cjags
Fixes: 4
Just got a link from openreach to their installtion video which says they need a double mains socket near the ONT.
I thought the ONT would need 1 mains socket.
Fixes: 357
You do only need a single socket within 1m of the ONT - the router can be wherever you like so so long as the Ethernet cable is long enough.
cjags
Fixes: 4
That's what I thought.  Plusnet hub is next to the current phone socket so ONT will likely be next to that. There is spare mains socket there.  Cheers.
Fixes: 105
@cjags
There is a bit of leeway as to where the ONT goes if you want a different location (same room usually as the MS).
Terranova667
Fixes: 8
@cjags I wouldn't assume that is where the ONT will go, The installer who did my install (was not Open Reach themselves) refused to put the ONT where my master socket and router was, he had nothing with him to do any work required to route the fibre cable other than where it was routed which for me was at the back of the house to the living room, I had waited 5 months for the installation at this point so couldn't be bothered telling him to go to get someone else willing to do the work, in the end I got a all-weather Ethernet cable and routed that from the ONT around the side of the house to the front and into the hallway where the master socket and router is, no issues at all and getting full speed.
Hopefully you get someone that is more willing to do the job and place it where you would like it to be, but be prepared that they may not.
cjags
Fixes: 4
Install day was today but the duct from the BT box to the premesis was well and truly blocked so it wasn't possible to get the fibre to the property.  Waiting for blockage team to come and clear the duct then OR can try again.
cjags
Fixes: 4
When connecting the plusnet hub2 to the ONT, the instructions say to use the red RJ45 socket on  the hub2.
The hub2 has 4 yellow RJ45 sockets with a red WAN label above the 4th one.  Is this the red socket?
Fixes: 139
@cjags
 Is this the red socket? - yes it is.
cjags
Fixes: 4
Openreach have done the FTTP installation and connected the Plusnet hub2 to the ONT and tested that it connects OK.  They have now gone but daughter has an issue with her mobile phone connection to the hub2 via wifi.
Before the istallation, her phone connceted OK.  Now the wifi connection asks for a wifi password (on her phone).
She enters the password from the back of the hub2 but it is not valid.
Does the hub2 create a new wifi password when it switches to FTTP from FTTC?
Fixes: 105
@cjags
Good to hear the duct was cleared without any major problems.
Did your daughter get  a new Hub2 for FTTP or is she still using her previous one? If new, the network SSID and password will have changed.
Fixes: 558
@cjags
No,
Unless the password had previously been changed and the engineer factory reset the Hub
Is she entering the wifi password OR the admin password ?
cjags
Fixes: 4
Same plusnet hub2.
Don't know if openreach did factory reset (I'm not there) but they were happy the hub had connected to the ONT and was working.
