Speed decrease after signing for a new contract
kwikfix
So after being out of contract for many years but staying with Plusnet I decided to take up a new 18 month contract.
The idea was to decrease my cost yet increase performance as I opted for the faster super fibre option.
Imagine my dismay after 24hrs to find my speed lowered by at least 10 mbps.
So not only did I not get the lower price offered to "new customers" I get my speed slashed.
Not impressed as a long serving customer, hearing friends brag about the super fast speeds they get yet mine is now slower & tied to a contract.
Yes I have done all the tests.
Yes I have waited weeks for it to settle in.
66 REPLIES 66
Fixes: 388
Re: Speed decrease after signing for a new contract
@kwikfix If you post screenshot results of  BT Broadband - obscuring your phone number, BTW Performance Tester - the 'Advanced Diagnostics' report, and your Hubs Help Desk - obscuring personal details, Community members may be able to advise.
kwikfix
Attached report
Fixes: 388
Thanks - and the other two? - they are needed to build the full picture.
kwikfix
kwikfix
kwikfix
Sorry I didnt understand what the "Hubs Help Desk" is?
Cabinet 25 Winsford Cheshire area if that is any use?
kwikfix
Your broadband service
  • Product: Unlimited Fibre Extra
  • Estimated Download Range: 31 - 46Mbps
  • Estimated Upload Range: 6 - 9Mbps
  • Minimum Guaranteed Speed: 29.4Mbps
  • Current Line Speed (Download): 21Mbps
Fixes: 388
@kwikfix A picture paints a thousand words. 😉
Also, was the speed test done over wireless or ethernet, and have you done a Quiet Line Test - dial 17070, option 2 - after your number has been confirmed there should be no noise on the line other than the regular 'Quiet Line Test' announcement.
kwikfix
Ahhhh thank you here you go.
Test was done over ethernet. I was getting 29mbps right before I swapped to faster package yet I received slower performance.
Fixes: 388
Thanks for that - it does appear there is something not quite right. Your D/S noise margin is higher than I would have expected, your uptime is very low - you don't turn the Hub off, do you?, and one vital line is missing - what 'User name' is showing on that page?
kwikfix
I only turn the hub off when experiencing even slower speeds or issues on my network.
My quiet line test was fine btw.
kwikfix
My username shows on the main home page of the hub, doesn't show on that helpdesk page.
Fixes: 388
OK. Do not turn the hub off though, you could eventually persuade the Dynamic Line Management in the cab to think you have a bigger problem than you do, and it may aggressively raise the SNR and reduce your speed, which I kind of suspect it has already started doing, looking at that data.
Good that the phone test is clear, and you have the correct user name in the hub - I was wondering if it hadn't completed setup correctly.
I can only really now suggest you wait for one of the Help Team to pick this up and run some slightly more advanced tests - sorry.
kwikfix
Thanks John. Yep something is certainly not right. I wasn't hoping for miracle jumps in speed maybe the possibility of over 40mbps but certainly not a drop from my consistent 29mbps for years to 19mbps overnight from the switch.
I don't reboot the router on a regular basis as a rule, I did do it tonight after sending you those pics but that was the first time in weeks.
