Stability Profile change
steve88
Is it possible to tell me what stability profile my line is currently set to as DLM doesn't seem to want to take off interleaving despite having low ES per day and no line drops. I think it might have been changed to STABLE as a first attempt when a reported a problem with line drops at the end of September. If it is can it be changed to STANDARD or even SPEED.
I am on a fibre FTTC connection about 950m from the cabinet. Starting at the end of September I had lots of problems with my connection dropping. It took a number of visits of a BT OR senior engineer who ultimately replaced about 300m of overhead line including the final dropwire. This new section of line has reduced downstream attenuation from 24.5db to 22.9db and there is a corresponding increase in speed 🙂
DL: 30.0M now 37.6M
UL: 4.76M now 4.93M
The line is has now been stable for a month with most resyncs either being DLM or me. All good apart from the interleaving, which I didn't have for  many months before the line fault (and maybe the negligible increase in UL speed)
Stats:
Stats recorded 27 Nov 2021 10:54:36
DSLAM type / SW version:	IFTN:0xb206 (178.6) / v0xb206
Modem/router firmware:  	AnnexA version - A2pv6C038m.d24j
DSL mode:               	VDSL2 Profile 17a
Status:                 	Showtime
Uptime:                 	15 days 8 hours 24 min 31 sec
Resyncs:                	0 (since 12 Nov 2021 13:48:56)
				Downstream	Upstream
Line attenuation (dB):  	22.9		0.0
Signal attenuation (dB):	Not available on VDSL2
Connection speed (kbps):	37615		4932
SNR margin (dB):        	6.6		6.6
Power (dBm):            	-0.2		-0.2
Interleave depth:       	737		1
INP:                    	3.00		0
G.INP:                  	Not enabled		Not enabled
Vectoring status:       	5 (VECT_UNCONFIGURED)
xdslcmd info --stats
xdslcmd: ADSL driver and PHY status
Status: Showtime
Retrain Reason:	6
Last initialization procedure status:	0
Max:	Upstream rate = 5504 Kbps, Downstream rate = 44100 Kbps
Bearer:	0, Upstream rate = 4932 Kbps, Downstream rate = 37615 Kbps
Link Power State:	L0
Mode:			VDSL2 Annex B
VDSL2 Profile:		Profile 17a
TPS-TC:			PTM Mode(0x0)
Trellis:		U:ON /D:ON
Line Status:		No Defect
Training Status:	Showtime
		Down		Up
SNR (dB):	 6.6		 6.7
Attn(dB):	 22.9		 0.0
Pwr(dBm):	-0.2		-0.2
5 REPLIES 5
Fixes: 1,662
Re: Stability Profile change
Thanks for your post @steve88
I'm really sorry for the issues you've had with your connection and I'm glad to see an engineer's efforts got things sorted.
I've placed an order to change the stability profile from Stable to Standard, which is the lowest it goes. This should start to take effect from Tuesday next week, but may take 7 to 14 days for DLM to react to the changes.
The speed profile you're referring to is Openreach's terminology for this. Taken from the Kitz website Here:
Stability Level WBC Profile (20/21CN) NGA Profile (FTTC) Description
1. Aggressive Standard Speed Prioritise speed over stability for online gamers
2. Normal Stable Standard Best overall balance between speed and stability
3. Stable Super Stable Stable Prioritise stability over speed for IPTV
'WBC Profile' refers to BT Wholesale's terminology and 'NGA Profile' refers to Openreach's.
Let us know how it goes. Smiley
steve88
Many thanks @Gandalf
I will add an update once the DLM has settled down again in 10-14days
Fixes: 1,662
No problem @steve88 sounds good
steve88
So here we are almost 3 weeks later and the profile change was successful.
Profile change occured early hours of 02 Dec 21.
DL speed went from 37.6M to 40M
UL speed went from 4.93M to 5.32M
Interleaving was removed so latency/delay dropped.
The line has been stable for the 2+ weeks since. Good result. Thanks @Gandalf
Stats recorded 16 Dec 2021 17:42:40
Status:                 	Showtime
Uptime:                 	14 days 15 hours 50 min 4 sec
Resyncs:                	0 (since 05 Dec 2021 08:21:51)
				Downstream	Upstream
Line attenuation (dB):  	22.6		0.0
Connection speed (kbps):	39998		5322
SNR margin (dB):        	7.0		6.0
Power (dBm):            	2.3		2.3
Interleave depth:       	1		1
INP:                    	0		0
Status: Showtime
Retrain Reason:	1
Max:	Upstream rate = 5210 Kbps, Downstream rate = 42364 Kbps
Bearer:	0, Upstream rate = 5322 Kbps, Downstream rate = 39998 Kbps
Mode:			VDSL2 Annex B
Trellis:		U:ON /D:ON
		Down		Up
SNR (dB):	 7.1		 6.0
Attn(dB):	 22.6		 0.0
Pwr(dBm):	 2.3		 2.3
Fixes: 1,662
Thanks for the update @steve88
Excellent! That's really good to see. Smiley
Let us know if you have further issues or there's anything else you'd need help with.
