Speed decrease after signing for a new contract
Mustrum
Fixes: 81
Re: Speed decrease after signing for a new contract
One thing you could do is to locate the test socket, remove the two screws on the Master Socket, plug the router in and repost the help desk tab.
As you have only just upgraded it may be that you do not have a filtered master socket and your speeds could be limited by any extension wiring you have.
If you scroll down on your Help Desk tab you should see your username and other info.
kwikfix
Out of interest what should be expected in regards to "D/S noise margin"?
Fixes: 388
OK, I only queried the Hub situation as it was showing a very short uptime, but you comment rules that out as a factor.
kwikfix
I only have one master socket, my router goes in direct with no extensions & I have no phones plugged in so no filter.
Fixes: 388
I would have expected it to be lower, maybe 6 - 8, but the increased level could be something to do with whatever is happening.
I would give @Mustrum 's suggestion a go too.
Fixes: 388
You need a filter - unless it is a filtered socket, even with no phone attached.
kwikfix
I basically have one socket with a phone socket (empty) and a socket that my router goes in directly.
Fixes: 388
Which socket - a photo would be ideal?
Any markings on it?
kwikfix
Well yes I can take a pic of the BT socket. I would re emphasise though that none of this is new equipment or new changes since my swap to fibre plus.
Fixes: 388
Understood - but I'm just curious. 😀
kwikfix
Fixes: 388
OK - it is a filtered socket, but maybe - if you have a 'dangly' filter - you could try it straight into the test socket, just to rule out a failing internal filter.
kwikfix
By "test socket" do you mean the empty one below the occupied socket John?
Strat
Fixes: 565
No, the one behind the faceplate.
Fixes: 388
Nope, @kwikfix - the one which is exposed if you unscrew those two screws and remove that bottom cover - there should be another socket behind that, into which you plug the filter, then plug your DSL cable into the corresponding socket on the end of the filter.
You was quicker than me, @Strat 😀
