Settings for Unifi Dream Router direct connection to FTTP
dwrightpn
Hi there
I'm trying to bypass my Hub 2 and connect my ONT straight into the WAN port of my Unifi Dream Router.
I followed this the instructions on this thread --> Plusnet fttp full fibre with Ubiquiti USG - Setup - Plusnet Community, but it doesn't work.
I've attached my settings in Ubiquity's Internet settings but it's not playing.
The only possible thing it may be, and this is another question - is your @plusnetdsl password the same as when you sign in to Plusnet's website?
I tried to find the password for this in my account details on the Plusnet website but couldn't find them.
Thanks for any advice anybody has.
- D
Tags (3)
10 REPLIES 10
Fixes: 385
Re: Settings for Unifi Dream Router direct connection to FTTP
- D
Yes, the @plusdsl password is your account password, which you should have kept a record - it is intentionally obscured in your online account, for security considerations.
dwrightpn
Thanks for confirming that that was the password I was using so it's not that which I've messed up then!
- D
Fixes: 581
@dwrightpn  but the real problems are:-
1) your username should end with @plusdsl.net NOT @plusnet.dsl
2) VLAN ID should be disabled NOT set to 101
dwrightpn
@MisterW
Oh. So maybe I was an idiot! I'll try that again and remove the VLAN, I did read that had to be set but let's give it a go!
Thanks in advance and if this fixes it then I'll mark your answer as the fix!
[UPDATE] This fixed it! Thank you for spotting my mistakes
- D
Fixes: 385
As  a mere mortal, I cannot see the settings referred to -  only the dreaded 'yellow triangle' 😀
Fixes: 117
That holding image really needs to state "Image under Moderation" for those not familiar with the process.
Perhaps one of the SuperUsers could flag this up to PN.
Fixes: 581
@bmc Its being discussed.
@jab1 you should be able to see it shortly... I'd forgotten you wouldn't be able to see it. I'm sure you'd have spotted it before me if you had.
Fixes: 385
@bmc I am familiar with it - it is just frustrating for those trying help to be unable to see what the issue is.
Fixes: 117
@jab1
You may be familiar with it and I am thanks to you but there will be others who have no idea what's going on.
@bmc
The process was announced in "Community Announcements"
See https://community.plus.net/t5/Community-Announcements/Where-s-my-image/td-p/2016880
Perhaps you missed it?
