FF installation query
fibre_4_me
hi,
i'm currently on plusnet's fibre package and considering upgrading to full fibre. The option to switch to full fibre is available when i login to my plusnet account. I live in an apartment on the fourth floor of a building constructed in 2006. Do you reckon there'd be any show stoppers in FF installation?
thanks
7 REPLIES 7
Fixes: 118
Re: FF installation query
@fibre_4_me
Use the following to see what it says.
Full FIbre shows up as WBC FTTP If there, what does it say to the right - Available, One Stage or KCI2
Below the results window there will be a narrative on the FTTP install. What does this say?
Fixes: 585
@fibre_4_me what does the BTwholesale checker https://www.broadbandchecker.btwholesale.com/#/ADSL/AddressHome say for your address. Particularly the 'FTTP Install process' column and the narrative below the Availability results
fibre_4_me
It says 1 stage
Fixes: 118
@fibre_4_me
Thanks for the results.
The key line is the first sentence of narrative after the results window. It states it is a MDU (multi dwelling unit) with no anticipated issues.
So OR know it's a block of flats. As ever with installs, you would only find out on the day if there are any problems.
fibre_4_me
thank you Brian
Fixes: 118
@fibre_4_me
Happy to help. I assume you know you'll lose your landline if this matters.
fibre_4_me
yes, thanks. I disconnected it years ago.
