Port 2 speed limitation — need service moved to port 1 but blocked by incomplete BT cease
FIXED- Subscribe to RSS Feed
- Full Fibre
- Re: Port 2 speed limitation — need service moved t...
- « Previous
- Next »
Re: Port 2 speed limitation — need service moved to port 1 but blocked by incomplete BT cease
2 weeks ago - last edited 2 weeks ago
When you post a reply, there's a 'paperclip' icon just below the reply box. However if you are using a phone or tablet then you will need to select 'desktop site' in your browser settings for it to show
edit: i see you found it.
Difficult to see from the photo but a pin 1 connection fault would cause exactly the problem we have i.e a fallback to 100Mb.
2 weeks ago
2 weeks ago
@wohdivad yes, give support a call and tell them about the damaged WAN socket. If you dont get a positive response then post back and I'll see if I can get someone to expedite a replacement.
2 weeks ago
2 weeks ago
Something like a paper clip might be able to lever the pin.
If you do try take the power out of the hub.
But as you have a working service it might be worth waiting for a new Hub.
2 weeks ago
2 weeks ago
The new hub arrive very promptly this morning and, no surprise, it works perfectly. WAN speed 1000 Mbps and I record a speed of approx 138 on a speed test. Spot on for a 145 contract. Thanks again for all your help, and the other forum members' input of course. Four weeks of grief sorted on a Sunday afternoon. I am asking for compensation so wish me luck!
a week ago
Is there any way to contact Plusnet other than by phone? The reason I'm asking is that due to a temporary medical issue I can't actually speak at the moment
a week ago
Hi @Slunnyboy
I'm sorry to hear that you're unwell at the moment. You could open a ticket through the member centre. Our customer support team will look into it and contact you back.
Chris
Monday
AFAIK its not possible to open a ticket (except for a complaint!) from the member centre and hasnt been for a long time!
In any case the problem has been sorted on @Slunnyboy s thread https://community.plus.net/t5/Full-Fibre/Full-Fibre-145-Speed-not-as-stated/m-p/2044442#M30640
Monday
Monday
- « Previous
- Next »
- Full Fibre
