Port 2 speed limitation — need service moved to port 1 but blocked by incomplete BT cease
Fixes: 463
Re: Port 2 speed limitation — need service moved to port 1 but blocked by incomplete BT cease
Moderator's note:
Thread moved from Broadband to Full Fibre
Fixes: 554
@wohdivad
Interesting, that shows the ONT is fine and so is the cable.
So just to confirm, using the same cable to connect the ONT back to the WAN port and the link speed shows back to 100Mb ?
If that's the case , then the Hub 2 is faulty.
pvmb
Seasoned Pro
Fixes: 11
@wohdivad wrote:
The ond is a Huawei Echo Life HG8240
That appears to be an ONT/router in its own right, intended for use in a business environment
https://manualmachine.com/huawei/echolifehg8240/
Should be able to connect to it via a browser and see what is going on - if you have password access, I presume.
"root" and "admin" seem to be the given defaults for User and Password.
Fixes: 137
@pvmb
I did note that about the ONT, however the OP does not have a wired ethernet port available.
Edit: See post 24.
Fixes: 554
@pvmb
Whilst the hardware might be capable , I suspect the Openreach implementation is locked down in functionality
wohdivad
Yes, confirmed
wohdivad
My laptop does not have the port unfortunately
wohdivad
Here is the log:
admin timeout from 192.168.1.203
16:30:47, 19 Apr.
A device connected to Ethernet port 3
16:30:47, 19 Apr.
Wire Lan Port 3 up, Speed 1000 Mbps
16:30:04, 19 Apr.
SIP WAN DOWN
16:30:04, 19 Apr.
WAN Sensing Auto sensing Complete, interface selected
16:30:04, 19 Apr.
WAN Sensing Auto sensing Running
16:30:04, 19 Apr.
WAN connection WAN1_INTERNET_ETH disconnected.[ERROR_NO_CARRIER]
16:30:03, 19 Apr.
PPP: Stopped PPP daemon(0,1,5)
16:30:03, 19 Apr.
PPP LCP Send Termination Request (User request)
wohdivad
And the WAN:
Product code:Plusnet Hub Two
Serial number:+R91298+2211003945
Firmware version:v0.10.00.04201-PN
Firmware updated:Unknown
Board version:R01
GUI version:1.9 16_08_2022
DSL uptime:-
Data rate:100 Mbps / 100 Mbps
Upstream error control:Off
Downstream error control:Off
Fixes: 554
Yes, confirmed
@Dan_the_Van can you see any other possibility other than a Hub 2 WAN port fault ?
Maybe I'll drop Bob a PM for his throughts
Fixes: 137
@MisterW
I would look into the WAN socket to see if any of the pins are missing
There is no setting on this Hub to change port speeds.
It might be worth a Hub factory reset?!
Fixes: 554
Yes, worth a look with a magnifier to compare the pins on the WAN port with one of the LAN ports, checking for missing or bent pins
Worth a try if we havent already done that...
@wohdivad are you up for that ?
wohdivad
Thanks again for your support. I’ll go and give it a go.
wohdivad
No change on reboot but, yes, the left pin of the WAN port looks faulty.  How can I attach a picture to show you?
wohdivad
