My router has broken
Fixes: 387
Re: My router has broken
Sadly, @JulieD42 , I agree with @MisterW  on this. That visit is a total waste of time and effort - the fault is in the OpenReach network.
Fixes: 585
Fault Symptom: No Sync
Que! How do they work that out ? the lights are showing fine on the ONT aren't they ?
Fixes: 585
All that happened was my husband went behind the tv, he untangled all the wires behind there then plugged them back in and that’s when the WiFi stayed with the issue.
@JulieD42  to be clear , was it working before your husband untangled the wires ?
JulieD42
I think next door do, I’ve sent her a message to ask.
JulieD42
I know. The3 lights are on the open reach box and orange light on the router?
Fixes: 480
@JulieD42
So again for clarification, this problem only started after your husband had unplugged and untangled a jumble of wires? If so then maybe it is a job for Qube.
Edit
My post crossed with that from @MisterW
JulieD42
Yes it was. I blamed him. Lol
Fixes: 480
@JulieD42
My money would be on that being correct. Are you sure that everything is plugged back in correctly and that there are no damaged plugs or sockets?
Fixes: 387
@Baldrick1 The ONT  is powered and operational, the Hub is powered - what else could be involved?
Fixes: 585
@JulieD42
you said earlier
Thank you, I’ll try that. In terms of the cable. It hues from the lan port on outreach box to wan port on router. Each end of the cable is red.
That sounds correct .
there's nothing plugged into the DSL port on the router is there ?
Fixes: 480
@jab1
I have no idea, maybe an impedance fault. These 1GHz links work in mysterious ways their wonders to perform. Else it's a low probability (but not impossible I grant you) coincidence.
JulieD42
Yes, I did a video call with Plusnet and we tried different sockets. Evenbsifferent ethernet cable to the openers box from the router… nothing worked. I said to my husband what the heck have you done? He said nothing I just untangled the wires and plugged it all back in. That’s when the solid orange light issue came on once he plugged everything back in but nothing Plusnet could suggest made it work again.
JulieD42
No, all we have plugged in is power cable and a cable from wan port that goes to lan on the open reach box?
This might help with each and everything
JulieD42
Yes so all we have is a red ended cable that goes from the lan port on open reach box to wan socket on the router. Nothing else is currently plugged in.
