My router has broken
Fixes: 569
Re: My router has broken
@JulieD42 have the router, and the ONT been switched off and back on ?
Fixes: 472
@JulieD42
With a paperclip or similar push it into the rest hole in the side of the Openreach ONT, hold it shut until the lights change. Then do the same on the Plusnet Hub, holding the switch closed until you get a green light.
Edit
Posts crossing again!@MisterW is thinking along the same lines. Try his solution first then if that doesn't work try mine.
JulieD42
Yes both have been switched on and off and I’ve reset my router twice
Fixes: 569
@JulieD42 in that case , its got to be worth doing the factory reset on the ONT as @Baldrick1 suggests.
JulieD42
Ok I’ve just done that, I did the ONT box until the lights went off and one turned red and reset router straight after. The router is still solid orange.
JulieD42
JulieD42
Moderators Note
Image removed as it displayed sensitive information.
Fixes: 569
@JulieD42 ok, I'm not sure there's much else you can do.
It does seem a bit too coincidental that it was working before the cables were disturbed but everything looks to be correct...
JulieD42
It does doesn’t it. I just don’t understand why as he just untangled them. I’m concerned them not sending a BT engineer will delay this even further.
I appreciate everyone’s help. Thank you.
markhawkin
Aspiring Champion
Fixes: 20
Nothing looks wrong from the photos.
It would be well worth plugging something (a laptop?) into the first Ethernet hole and seeing what happens.
I suspect you will see some sort of fault page in a browser (192.168.1.254 as previously detailed).
With a reset of the Openreach ONT and the router, when plugged in it should all "come good" however it might have previously been upset.
Fixes: 374
Just an observation, before I try something more relaxing for the rest of the afternoon, but if the PADI are being sent, but not acknowledged, does that not rule out an internal issue?
Fixes: 569
@jab1 yes it would appear to. The log confirms the router is trying to send the PADI and the LAN light flashing on the ONT would seem to confirm they are going out.
It just seems too coincidental that is was working before...
MatthewWheeler
Fixes: 503
Thanks for confirming @JulieD42
After doing everything you've been asked for above it's changed the way the line is testing and we're no longer seeing an issue with the connection between the router and the ONT.
Can you try turning both off for two minutes and then back on to see if this helps out?
As of the 1st of January 2026, I no longer work in Plusne,t so I'll be unable to assist you with any queries.
JulieD42
Just done. Still orange. What on earth could this be?
Fixes: 569
@MatthewWheeler does @jab1 s suggestion earlier of a stale session have any possibility ? although you would have thought that any session would have long since timed out and cleared by now
