Hub 2 port speeds
baccini
Re: Hub 2 port speeds
Got one ordered it will be Wednesday when it's delivered
pvmb
Aspiring Champion
Fixes: 15
@jab1 wrote:
Don't know where you've seen that term, but I'm guessing it is a term used to 'describe' a Windows machine.
Nope!
"dos box" (should be "DOS box"?) was the original term for a window in earlier versions of Windows for running PC/MS DOS programmes and the old DOS CLI, COMMAND.COM.
Long gone from Windows (with the advent of 'real mode' 32 Bit versions of Windows), superseded by the current version based on COMMAND.EXE, the Windows Command Window (Command prompt) which cannot run DOS programmes. Though the CLI has many features and commands that are the same or similar to the original DOS CLI ones using COMMAND.COM.
From habit and for convenience many still refer to this as a Windows "DOS box" - though it could more properly be called 'DOS box', as the real DOS box is merely a memory.
I'd also be interested with that.
@baccini wrote:
100000000
100,000,000 - that is a 100 Mbps link
1,000,000,000 - would be a 1000 Mbps link
The laptop being used how old is it, any idea on the network interface details.
Maybe share the laptop Full model details, it might be the ethernet interface speed setting has be miss configured
The wmic nic where netEnabled=true get name, speed should reveal the 'nic' (network interface card) details
baccini
baccini
Fixes: 579
@baccini that's the details for the Wireless NIC , I understood you were using a wired (ethernet) connection ?
@Dan_the_Van minor issue with your wmic command , its doesnt like the space between name and speed
wmic nic where netEnabled=true get name,speed
works though
baccini
Ethernet is 3MB
baccini
Fixes: 579
I think the 'FE' means Fast Ethernet , which is 100Mb. In which case it seems the NIC is only capable of 100Mb. That would explain why changing the cable made no difference
baccini
looks like the mystery has been solved could have sworn I got 150Mb in the past,thanks guy's
If it's important to you could buy a 1000 Mbps USB device, just make sure you disable the existing ethernet NIC
Fixes: 480
@baccini
This is the result that you need:
There is an equivalent Power Shell command which I prefer, (it doesn't mind spaces!)
PS C:\> Get-NetAdapter | select interfaceDescription, name, status, linkSpeed
interfaceDescription                           name       Status LinkSpeed
ASIX USB to Gigabit Ethernet Family Adapter #3 Ethernet 5 Up     100 Mbps
Realtek USB GbE Family Controller              Ethernet 4 Up     100 Mbps
ASIX USB to Gigabit Ethernet Family Adapter    Ethernet 2 Up     100 Mbps
Intel(R) 82578DM Gigabit Network Connection    Ethernet   Up     1 Gbps
VirtualBox Host-Only Ethernet Adapter          Ethernet 3 Up     1 Gbps
Fixes: 245
That is indeed interesting.
Bluetooth Device (Personal Area Network) Bluetooth Network Connection Disconnected 3 Mbps
Intel(R) Wi-Fi 6 AX201 160MHz WiFi Up 650 Mbps
ExpressVPN Wintun Driver Local Area Connection Disconnected 100 Gbps
ExpressVPN TAP Adapter Ethernet 2 Disconnected 1 Gbps
And that is with a Hub Two ... so is that just potential capability?  The PN Hub Two is not WiFi 6 and I doubt it can do anywhere near 650mbps.
Easy to use WiFi Analyser reports the 5GHz band as running at 54mbps and the 2.4GHz band running at 144mbps.
