Hub 2 port speeds
baccini
Hub 2 port speeds
Why do I get different speeds from the three ports i'm connected to 150Mbs line desktop speed 140 to 150Mbs constant for almost 2 year on a 25meter cat 6 cable yet when i connect my laptop with a 2 meter cat 5a cable to another port 90Mbs speed.What speed should i get when i connect direct to the ONT with my laptop i'm getting 90Mbs confused
32 REPLIES 32
Re: Hub 2 port speeds
All ports on the Hub Two and ONT are auto negotiate up to 1000Mbps, your symptoms suggest a defect cable.
The speeds achieved directly connected to the ONT will be that of your contract.
EDIT or @MisterW suggestion
SECOND EDIT: try this command in a dos box
wmic nic where netEnabled=true get name, speed
Fixes: 579
Sounds like your laptop might only have a 10/100! nic
baccini
Forgot to mention WiFi gives me 150mbs on the laptop
Fixes: 382
As said  above then - dodgy cable.
baccini
Tested today new cat 5e got 90Mbs I've ordered a cat 6 just to rule out cable which I think I already have
Fixes: 382
Have  you tried the current cat6 on the laptop?
pvmb
Aspiring Champion
Fixes: 15
Crikey! That wmic is a powerfully complicated command (being trying it out in my Win 8.1 machine - is deprecated for Win 10 and beyond). I might even be able to use it to investigate some questions I previously had about a little Wi-Fi adaptor I bought for my PC.
I found this link: https://www.cyberithub.com/20-useful-wmic-command-examples-in-windows-cheat-sheet/
baccini
What's a dos
box
Fixes: 382
Don't know where you've seen that term, but I'm guessing it is a term used to 'describe' a Windows machine.
Sorry old name, it's the Windows Command Prompt
I have a Linux command if you use that os
Fixes: 382
Interesting @Dan_the_Van - any chance you could share it for a Linux 'newbie'?
@jab1
I'll PM you the command tomorrow as there is a couple of steps for it
Fixes: 382
Cheers, Dan.
baccini
100000000
