FTTP - iPlayer over Wii buffering
- Full Fibre
- FTTP - iPlayer over Wii buffering
21-06-2011 12:42 PM
Hi, I tried to catch up on a program I missed the other day on iPlayer on the Wii (so it outputs to the TV) and it was unwatchable as it kept erroring and reporting my bandwidth was insufficient. Any suggestions as to what I need to do to resolve this? I don't think it should be buffering or reporting insufficient bandwidth on a FTTP connection.
Internet connection test from Wii to internet was successful although I also had issues trying to go into the Wii shop channel to check if I needed an iPlayer channel update.
Any ideas?
Cheers, Paul
Any ideas?
Cheers, Paul
Message 1 of 4
(2,709 Views)
3 REPLIES 3
Re: FTTP - iPlayer over Wii buffering
21-06-2011 1:42 PM
Message 2 of 4
(565 Views)
21-06-2011 3:24 PM
Your setup probably isn't anything like mine, but...
Of all my wireless devices the Wii has the worst wireless performance. It will connect and do updates etc., very slowly, but I have never been able to watch iPlayer on it. Put another way, it isn't the speed of my internet connection that is limiting it.
I shall be trying Epyon's test, from the Wii, later.
Message 3 of 4
(565 Views)
22-06-2011 6:56 AM
That bbc test doesn't seem to work on the Wii. And when I tried it, iPlayer was watchable.
What I was trying to say though, was to be sure the connection between Wii and your router is working well (although how you can tell I do not know). The Wii may connect to the internet but that says nothing about the quality (i.e. speed) of the connection.
Message 4 of 4
(565 Views)
- Full Fibre
