FTTP Marketing
Fixes: 1,662
Re: FTTP Marketing
Cool. I've raised tasks to transfer your .co.uk domains, which should be done within 3 to 5 working days.
For the .com domains, do you want the EPP code emailing to the usual email address we have for you on file?
ecomergy
Re: FTTP Marketing
Yes, that would be ideal.
Many thanks
Fixes: 1,662
Re: FTTP Marketing
I've just began raising the tasks to transfer those .com domains and we aren't actually registering them.
who.is check shows that eNom is the registrar. If you contact them you'll be able to request an EPP code. You're just using our nameservers to host the domains, but you can easily override that by asking another provider to host them instead.
ecomergy
Re: FTTP Marketing
How extraordinary. I've never had any ISP other than you guys and did register them via you, though we are talking like 19 years ago nearly.
Any idea of how I go about contacting 'eNom?' Icann lookup gives an abuse contact email address for them but not much else
Fixes: 1,662
Re: FTTP Marketing
It may be worth starting here https://www.enom.com/reseller/contact-us/
ecomergy
Re: FTTP Marketing
Thanks. Will do
Fixes: 1,662
Re: FTTP Marketing
Cool. No problem, let me know how it goes.
ecomergy
Re: FTTP Marketing
Will do.
These are the only two .com's so I hope the rest will be straightforward.
Fixes: 1,662
Re: FTTP Marketing
Sounds good, it’s worth doing a who.is check of the other domains as well just to check we’re the registrar.
Fixes: 579
Re: FTTP Marketing
@ecomergy i would guess that your domains are registered via an Enom reseller, otherwise you would have noticed youre being billed in USD!
This https://help.enom.com/hc/en-us/articles/115001924872-Who-is-my-reseller- might help
Fixes: 579
Re: FTTP Marketing
@Gandalf Oops , this could be a bit embarrasing!
I tried the reseller lookup on gwyneddhotel.com and guess who the reseller is :-
PlusNet PLC !!!
Looks like PN might use enom re register .com domains ?
Fixes: 1,662
Re: FTTP Marketing
Whoops. Well this goes to show how often I handle .com domains!
@ecomergy, I've raised the tasks now to provide the EPP codes. Should be picked up within 3 to 5 working days.
Fixes: 579
Re: FTTP Marketing
Totally understandable, I guess they are few and far between...
ecomergy
Re: FTTP Marketing
Guys, that's great news, and did make me giggle as well lol.
Many thanks for your help
Fixes: 1,662
Re: FTTP Marketing
Haha no problem.
Happy to confirm visitllanberis.co.uk has been transferred now.
I'll update when the others are picked up.
