FTTC to FTTP upgrade questions
Fixes: 102
Re: FTTC to FTTP upgrade questions
@NC23
Are you happy with the dig re-instatement and the likely location of the CSP?
NC23
@bmc Yes as predicted on my badly drawn floor plan, it was exactly where I planned it to be.
Just means an external cable needs to be run along the bottom part of the house to where the ONT ultimately will be.
