FTTC Expansion?
- Full Fibre
- Re: FTTC Expansion?
Re: FTTC Expansion?
26-08-2010 6:25 PM
If the other 2 that are affected are reading, so long as bluewhale's order is accepted I'll retry your orders tomorrow.
Plusnet Technology
Re: FTTC Expansion?
26-08-2010 7:17 PM
any chance of one of those new routers your testing 😉
anyone need any c# dev work doing? going cheap...
Re: FTTC Expansion?
26-08-2010 8:50 PM
Plusnet Technology
Re: FTTC Expansion?
26-08-2010 11:14 PM
I ahve two questions really:
The wiring into my house doesn' t however have an NTE5 master socket - I assume BT would install a new socket when they install the FTTC?
and I've read that they will install an extension kit if needed to site the router somewhere else in the house, but they won't drill through walls etc (which i understand) - would they feed through already drilled holes?
Re: FTTC Expansion?
27-08-2010 5:01 PM
Plusnet Technology
Re: FTTC Expansion?
27-08-2010 5:35 PM
as currently our phone is also at the end of an extension line
or could we get the master socket moved?
guess i'll see when they come, maybe a bribe of some choccy biscuits 🙂
Re: FTTC Expansion?
31-08-2010 10:11 AM
Plusnet Technology
Re: FTTC Expansion?
31-08-2010 11:30 AM
Can you tell me how many cabs this postcode is connected to?
For FTTC I get a yes by postcode check but no by phone number checking.
HX3 0AT
Paul
Re: FTTC Expansion?
31-08-2010 3:06 PM
Plusnet Technology
Re: FTTC Expansion?
31-08-2010 6:53 PM
Quote from: dave Hi Paul, 90% of lines on that postcode are covered by cab 14, 10% by cab 74. Cab 14 is on the to do list, but isn't done yet. Cab 74 isn't in the plan. I'd keep checking your phone number and see if it changes.
I dont suppose you have locations of cab 14 and 74?
Paul
Re: FTTC Expansion?
31-08-2010 7:21 PM
I am currently on ADSL cabinet 10, they have only put one Fibre cabinet up, we have two old ones either side of the end of my road, mine is to the right, the other to the left has the new cabinet next to it
Re: FTTC Expansion?
03-09-2010 9:49 AM
just to say the nice openreach engineer has been and gone. so now on fttc. working ok.
engineer very kindly moved the line box to near the PC.
although download still capped by plusnet profile i think, is that correct can it be reset or will it do it istelf at somepoint?
upload speed at 8mb.
have to say the master box are very big, about 2 inches deep, so sticking right out of the wall, can see myself banging the hoover into it.
cheers
pete
Re: FTTC Expansion?
03-09-2010 1:22 PM
Excellent. I've changed the profile over now for you, you might need to disconnect and reconnect for the change to take effect. I've not got the FTTC faceplate but I've got one similar and know what you mean about the size, thankfully mine's out of the way.
Plusnet Technology
Re: FTTC Expansion?
03-09-2010 1:40 PM
so now just got to wait till my change of account happens in Oct I think ( why is it stated as a downgrade btw )
not too happy having to have 2 boxes running all the time though, makes a mockery of all the power saving i've done..
is there anyway of getting a vdsl modem/wireless router all in one?
Re: FTTC Expansion?
03-09-2010 8:36 PM
Plusnet Technology
