Acceptable download, poor Upload
mcaddy
I pay for 40/10 Fibre, I currently get 38/2. The poor upload rate really holds us back, with the kids getting older and multiple people home schooling / online we regularly get warnings about network issues from zoom/teams/etc. Spoke to support tonight to be advised that 2mb might just be all I can get.
I'm at the end of my contract and with the BT Wholesale advising Low of 60/18.8 and high of 80/20, even for an impacted line, I'm wondering if the issue is within Plusnet and maybe it's time to move my business elsewhere?
Tech support have said they are going to further look into things but after a line test didn't show any errors I got the impression that they had reached the limit of there access/investigations and wasn't much that could be done.
It's been confirmed that I am indeed on the correct profile (i.e. 40/10 not 40/2). I would happily upgrade to 80/20 if that made any difference but I'm assuming it wouldn't? if I remain on 2mb upload then it'll be time to find another way to connect to the internet.
I've seen some others on here make good progress on escalations or more in-depth testing so spreading my bets in the hope that something works out.
15 REPLIES 15
Mustrum
Fixes: 81
Re: Acceptable download, poor Upload
@mcaddy  welcome to the forum.
Can you enter your phone number in the BTW DSL checker, and post the results?
Make sure you hide your number.
mcaddy
Telephone Number 01604XXXXXX on Exchange DUSTON is served by Cabinet 56
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Handback
Threshold(Mbps)
WBC FTTC Availability Date WBC SOGEA Availability Date Left in Jumper
High Low High Low
VDSL Range A (Clean) help 80 64.6 20 19 58.4 Available Available --
VDSL Range B (Impacted) help 80 60 20 18.8 52.2 Available Available --
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install Process
FTTP on Demand 330 50 -- Available --
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) ADSL Availability Date Left in Jumper
WBC ADSL 2+ Up to 2 -- 1.5 to 4 Available --
WBC ADSL2+ Annex M Up to 2 Up to 0.5 1.5 to 4 Available --
ADSL Max Up to 1.5 -- 1 to 3.5 Available --
WBC Fixed Rate 1 -- -- Available --
SOADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) WBC SOADSL Availability Date Left in Jumper
WBC SOADSL 2+ Up to 2 -- 1.5 to 4 -- --
SOADSL Max Up to 1.5 -- 1.5 to 4 -- --
SOADSL Fixed Rate Up to 1 -- 1 to 3.5 -- --
Observed Speeds VDSL
Max Observed Downstream Speed 53.93
Max Observed Upstream Speed 2.23
Observed Date 2022-02-01
Other Offerings Availability Date
VDSL Multicast Available
ADSL Multicast Available
Premise Environment Status
Bridge Tap U
VRI N
NTE FacePlate N
Last Test Date 20-01-2022
Exchange Product Restrictions Status
FTTP Priority Exchange N
WLR Withdrawal N
SOADSL Restriction Y
Mustrum
Fixes: 81
OK, thanks, that does not look good, your speeds should be much better.
Have you had an engineer out, and do you have a modern filtered master socket?
mcaddy
Just thought to check my Unifi logs and can now see that the 2mb upload is a very recent thing, Looks like downloads were also impacted for a while but that is recovering. We've all been home as our daughter has Covid right now so it's been very apparent this week. Can I expect things to sort themselves out? speedstats.png
mcaddy
No engineer yet
The Master Socket says 5C on the upper edge and Mk4 on the front does that make it a filtered socket?
Mustrum
Fixes: 81
Yes, that sounds like a filtered socket.
You say its a recent thing, has the modem/router been rebooted since the issue started?
mcaddy
I don't believe so, we did have a power cut 10 days ish ago but that is before the issues begun, the Unifi gear is set to auto upgrade so there is a chance it would have restarted itself in the process.
Would a restart of the Open Reach modem and our the UDM Pro (Router) be advisable?
Mustrum
Fixes: 81
In a worf - yes.
If you still have the old Openreach modem, it could be faulty.
If you have recently started a new contract it would be worth asking PN for their new Hub2 as it can work in bridge mode - unlike the Hub1.
mcaddy
I do indeed use the original Openreach modem.
Have been using Unifi routers of differing capabilities for the last 4 years. Currently at the end of term again so I will mention the Hub 2 when I speak to Tech Support tomorrow.
I'm guessing a Hub2 in bridge mode would replace the Open reach Modem, whilst avoiding any form of double NAT?
Mustrum
Fixes: 81
Yes, good guess.. Plus you will be able to get DSL line stats to help in the event of broadband issues.
Have you rebooted it yet?
mcaddy
My partner is still streaming, a reboot is a job for the morning, once she has gone to work!
Mustrum
Fixes: 81
Cool, let us know how it goes.
adam945
Fixes: 113
Thanks for reaching out @mcaddy and I'm sorry to hear that you've been having issues with the upload speed. The graph you've provided above looks identical to an RRT on my side, so there was clearly an issue,
Anyway, has the router reset helped? A GEA test on the line today is showing upload speeds of 10Mbps (the RRT is always a day behind so it's not clear on there).
KBD
GEA Test Detail
Circuit ID NA Service ID
Test Outcome Pass
Main Fault Location OK
Sync Status In Sync
Downstream Speed 40.0 Mbps
Upstream Speed 10.0 Mbps
Appointment Required N
Fault Report Advised N
NTE Power Status PowerOn
Voice Line Test Result Pass
Cross Talk Not Detected
Estimated Line Length In Metres 458.3
Upstream Rate Assessment Very Good
Technology VDSL
DP Type External
Profile Name 0.128M-40M Downstream, Error Protection Off - 0.128M-10M Upstream, Error Protection Off
Time Stamp 2022-01-22T11:45:00
 Adam
 Plusnet Help Team - Leeds
mcaddy
Thanks for the follow up, a reset of the Open Reach Modem was all that was required to restore my upload speeds.
I'm now looking at re-contracting in order to get the Hub 2 in the hope that I can avoid any similar problems recurring in the future.
Given the "Very Good" assessment on the GEA Test does that mean I can expect the near 80/20 speeds on Extra?
Obviously I wouldn't hold you to anything, just wondering if it's worth the extra few pounds per month. The website initially suggest moving up to extra was only going to get me about 50mb, but maybe that was using data from when my line was degraded?
