Outage in Newtown Powys
shazzbot
Hi my router is connected but no internet since 6am. Do you know if there is an issue in my area?
10 REPLIES 10
Fixes: 334
Re: Outage in Newtown Powys
@shazzbot Which Hub are you using, and what is the colour of the lights?
shazzbot
Hub2 and blue
Fixes: 334
OK , so the router is still connected to the internet according to that. What happens if you try to connect with a site?
When did you get a (PN?) Hub2?
shazzbot
Yeh it says internet is connected and when I try to connect my to a site it just takes me to router page.
Bought the hub 2 from EBay a couple of months ago.
Fixes: 334
Ah, OK, so it is an ex-BT one - strange because I thought BT now charged you if you didn't return them, but no matter.
What is the 'username' showing on the Hub? It is possible this has been returned to 'setup'?
shazzbot
Yeh it’s setup@plusdsl.net. I can’t remember it ever being anything different lol
Fixes: 334
OK - in that case, you need to reset it to 'yourusername@plusdsl.net' and your account password - it will never work correctly with that username.
shazzbot
Woohoo you genius. That was the problem. All connected now. Not sure why it would suddenly change it back to default. Thank you very much.
Fixes: 334
Glad you sorted it. I'm no 'genius' - just someone who knows what can go wrong with the 'net.
LaurenB
Fixes: 131
Hiya @shazzbot, I am really sorry to hear that you have experienced some downtime with the service, though pleased @jab1 has now managed to help resolve this for you Smiley
Should you have any further queries at all, please do just get back to us.
 Lauren Barry
